    Firmware 3.0 and 2 Simple FilamentSonsors
    • CupaCabra
      CupaCabra last edited by
      Hello, i have connected 2 Simple Filamentsonsors on my Duet3D Board. The Led‘s shows On/Off when I take the Filament into the Sensors but i don’t have a Status Massage in the Webbrowser.
      The Trigger always shows that is no triggert.
      I use the E0 and E1 endstops
      Config.g
      M591 P3 C"e0_stop" S1 ; filament monitor connected to E0_stop
      What’s going wrong.
      • droftarts
        droftarts administrators @CupaCabra last edited by
        @CupaCabra You need a 'D' parameter, related to the extruder drive each filament sensor is connected to. If 'D0' is your first extruder drive, your command would be M591 D0 P3 C"e0_stop" S1. Then you can get the status of the filament sensor with M591 D0.
        See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M591_RepRapFirmware_Num_3
        • CupaCabra
          Thx 4 the fast helping 🙂 I wil Do the test tomorrow and report.
          • CupaCabra
            Thx, it works 🙂
            Awesome
