    Installing BLTouch clone
    180
    • SerFabio89
      SerFabio89 last edited by
      Good evening everyone! I installed a Duet Wifi into my Davinci Pro 1.0. I also attached a BLTouch clone (latest version of TriangleLab's 3DTouch) but I'm not able to configure it properly. It retracts, and acts as it should be every time i run the mesh grid compensation I receive "Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh." Moreover the "show mesh grid heightmap" return an empty map.
      Any suggestions?
      Regards,
      Fabio
      • Danal
        Danal last edited by
        Are you running firmware V3 or V2?
        • SerFabio89
          Firmware Version: 2.05.1 (2020-02-09b1)
          WiFi Server Version: 1.21
          Web Interface Version: 1.22.6
          I have a custom machine as I wrote before. I'm trying to understand how the BLTouch works, in order to obtain an automatic bed calibration before each print. I have all optical min endstops (X, Y, Z) installed (and working) plus the BLTouch. I need a guide to mount it I think. For example, at which offset the tip of the BLTouch should be wrt the nozzle? Should I disable the z min endstop?
          Bests,
          Fabio
          PaulHew 1 Reply Last reply Reply Quote 0
          • PaulHew
            PaulHew @SerFabio89 last edited by
            @SerFabio89 The BL Touch in your case a clone, replaces the Z stop switch.
            Please post your config.g
            If you have 'Independent' motors on your Z axis, I think you can use bed levelling.
            Because your bed is tilted slightly you are receiving the warning about the Z offset.
            If you only have 1 Z motor you will need to manually level the bed.
            Some helpful guides, just incase you have not found them previously
            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
            HTH
            Paul
            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
            • SerFabio89
              This is config.g:
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 27 2020 22:15:04 GMT+0100 (Central European Standard Time)
              M550 P"Phoenix3D" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S1 ; enable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P2 S1 ; physical drive 2 goes forward
              M569 P3 S1 ; physical drive 3 goes forward
              M92 X80.00 Y80.00 Z2552.00 E100.00 ; set steps per mm
              ;M566 X900.00 Y900.00 Z12.00 E500.00 ; set maximum instantaneous speed changes (mm/min)
              M566 X1000.00 Y1000.00 Z25.00 E500.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              ;M201 X500.00 Y500.00 Z25.00 E250.00 ; set accelerations (mm/s^2)
              M201 X1000.00 Y1000.00 Z25.00 E500.00 ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1000 E1200 I15 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ; Silent drives
              M569 F1 P3
              M569 F2 P2
              M569 F2 P1
              M569 F2 P0
              M569 B2 P0
              M569 B2 P1
              M569 B2 P2
              M569 B2 P3
              M208 X240 Y240 Z200 S0 ; set axis maxima
              M574 X1 Y1 S1 ; set active low and enabled endstops
              M574 Z1 S2 ; set endstops controlled by probe
              M307 H3 A-1 C-1 D-1 ; disable heater 3 - used for probe
              M558 P9 H2.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X35 Y15 Z2.52 ; set Z probe trigger value, offset and trigger height
              M557 X40:200 Y40:200 S80 ; define mesh grid
              M305 P0 T100000 B4450 C0 R4700 ; set thermistor and ADC parameters for heatbed
              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
              M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              ; Custom settings
              M307 H4 A-1 C-1 D-1 ; disable heater 4 to repurpose gpio - ligths
              This is homeall.g:
              ; homeall.g
              ; called to home all axes
              G91 ; relative positioning
              G1 H1 X-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H1 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G1 H1 Z-225 F360 ; move Z down stopping at the endstop
              G90 ; absolute positioning
              ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
              ;G91 ; relative positioning
              ;G1 Z5 F100 ; lift Z relative to current position
              ;G90 ; absolute positioning
              With this configuration i cannot home all axis without an head crash. Now I'm trying to understand how to modify homeall.g in order to have an accurate calibration before the print starts.
              Later, how to force the print to run a mesh leveling and apply the mesh before each print?
              Regards,
              Fabio
              • PaulHew
                @SerFabio89 said in Installing BLTouch clone:
                Try changing you M574 to 1 line with this
                M574 X1 Y1 Z0 S1 ; Set active high endstops
                Do you have 2 motors on your Z axis or 1?
                Regards,
                Paul
                • SerFabio89
                  I have a single motor on the Z axis. Anyway I manage it to work. But would be nice if you @PaulHew can double check it. The config.g remained the same. Instead I changed homeall.g as the following:
                  G1 H1 X-1000 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H1 Y-1000 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H1 X-1000 Y-1000 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  ;G1 H1 Z-1000 F6000 ; move Z down stopping at the endstop
                  M280 P3 S160 I1 ; Alarm Release and Push-Pin UP
                  G30 ; probe current position to reach the endstop
                  G1 H1 X20 F3000 ; compensate for gap between nozzle X and Y and real position in the printer
                  G92 X0 Y0 Z5.02 ; set Z position to axis minimum (you may want to adjust this) - it includes the G30 dive height and the height difference between bltouch trigger and nozzle
                  Now the home all command (G28) correctly positions the nozzle at the origin but remains lifted 5.02mm (that is the distance between the trigger point of the bltouch and the tipo of nozzle). I also took into account the x offset of the nozzle.
                  Is this the correct approach to setup the printer?
                  If i change:
                  G1 H1 X20 F3000
                  G92 X0 Y0 Z5.02
                  with only
                  G92 X-20 Y0 Z5.02
                  will it work? does it accept negative values?
                  Bests,
                  Fabio
                  • PaulHew
                    PaulHew last edited by
                    Fabio,
                    New homeall.g
                    ;Z Probe Homing
                    G1 X140 Y140 F6000        ; go to first bed probe point and home Z
                    G30                     ; home Z by probing the bed
                    Please post your deployprobe and retract.
                    Regards,
                    Paul.
                    • SerFabio89
                      deployprobe: M280 P3 S10 I1
                      retractprobe: M280 P3 S90 I1
                      the homeall.g that you have posted is yours? i tried but it does not take into account the offset on z I think. I try
                      • SerFabio89
                        The latest revision of my homeall.g is:
                        ; homeall.g
                        G1 X20 Y0 F3000 ; move the nozzle to be in real 0,0,Z position
                        G92 X0 Y0 ; compensate for gap between nozzle X and Y and real position in the printer
                        ;Z Probe Homing
                        G1 X75 Y95 F6000 ; go to first bed probe point (heatbed center)
                        G1 X0 Y0 Z10 ;Go to origin with z lifted by 10mm
                        IT WORKS as expected!
                        Thank you very much for the help
                        Bests,
                        Fabio
                        • PaulHew
                          This line in your config.g sets the Z offset.
                          Homez.g does the homing for Z
                          my Homez.g
                          G91
                          G1 Z5 F800 S2
                          G90
                          G1 X140 Y140 F1000
                          G30
                          G1 Z2 F200
                          regards.
                          Paul.
