G30 Z Crashing issue
Updating the firmware from 1.15b to 1.18.1 solved the problem!
Here is a video! Thank you guys, love you all
Is there any way to Donate for Duet or the forums? ?
https://youtu.be/nVCJJLAbHAA -
Aaah missed that you were running an older firmware, I am glad you sorted it out!
Seeing from the video, it seems that you probe is not aligned straight with the bed? -
Yeah, for safety I installed the probe higher so it would trigger before the nozzle could crash in the bed and I can react
Now it's calibrated better and I think tomorrow I'll start the first print
Again, thanks guys!
Its great you got the problem solved. However that looks like a very solid machine, you might find if you manually level that bed (use the probe to help) you might not need any bed compensation, that's tooling plate too, so I'd be surprised if you have anything but a flat height map.
Don't get me wrong I am quite into z-probe tech (www.precisionpiezo.co.uk), but for solid cartesian machines a probe might not actually offer much. I stopped using bed compensation on my corexy as the z-axis barely ever moved so the bed was flat and level. For deltas and less solid cartesians then probing saves a lot of time.
At that time I started the post, i did not have any adjusting possibilities for the bed
Now I installed a 3Point system for Pre-Adjusting the printbed
Actually I'm fighting with the first print, somehow it shuts down the heaters when I start a print, but that's another Story
The problem in this thread is [Solved]
