    Need help setting up piezo probe with RR configurator
    • luckyflyer
      luckyflyer last edited by
      I can't select "Smart Effector or Piezo" on the endstops page. Also I'm not sure how to configure the I/O mapping page for a piezo probe, should I assign an endstop pin to Z (under drives)? The signal output of the piezo is active low acting like a switch. I tried several configurations on both the endstops page and I/o mapping page but was never allowed the "Smart Effector or Piezo" option on the endstops page. I have Duet 3 board selected.
        Phaedrux Moderator @luckyflyer last edited by
        @luckyflyer said in Need help setting up piezo probe with RR configurator:
        Not quite. You'll need to define the pin you're using in the Z probe section on the io mapping page, that should allow the z probe option selection in the endstops page.
        Where have you connected the piezo?
        • luckyflyer
          luckyflyer last edited by luckyflyer
          I finally got the Orion piezo working by studying the Gcode files and searching old posts to see what others have done and then editing the config.g file. An all day project but didn't have much else to do. Plus by doing it this way I get to have that great Ahh moment when I got it working.
            That's what keeps me going.
