    Solved How to I make probe stop sooner
    • TPJensen
      TPJensen last edited by
      Hello I just got a wham bam kit for my Anycubic Predator, but I would like to know how do I get my probe to stop the fast dive sooner so it dont crash into the bed before leveling it.
      Here is my config files
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
      ; Delta Settings
      M665 L440.000 R227 H456.0 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
      M552 S1
      M550 P"Anycubic Predator" ; Set machine name
      M551 P"" ; Set password
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80.00 Y80.00 Z80.00 E425.77 ; Set steps per mm
      M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Retraction
      ;M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P4 H3 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z16.0 ; Set Z probe trigger value, offset and trigger height
      M557 R115 S20 ; Define mesh grid
      G29 S1 ; Load the heightmap
      M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S255 ; Set temperature limit for heater 1 to 240C
      M106 P2 S0 I0 F500 H-1 ; Set fan 2
      M563 P0 D0 H1 F0:2 ; Define tool 0
      M572 D0 S0.1 ; Pressure Advance
      ;M591 D0 P2 C4 S1 ; Activate filament sensor
      M404 N1.75 ; Set for print monitor
      M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0
      T0 ; select first tool
        See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Running_auto_calibration_for_the_first_time in particular the bit about increasing the dive height.
        TPJensen 1 Reply Last reply Reply Quote 0
        • deckingman
          deckingman last edited by
          Also, it's generally a good idea to reduce motor current when homing or probing if at all possible, as it will help to limit damage if anything goes horribly wrong.
          • TPJensen
            TPJensen @dc42 last edited by
            Thank you That did the job 🙂
            • TPJensen
              TPJensen @deckingman last edited by
              @deckingman
              I did that and I can see that could have been a good thing to do if it went wrong
