    Duet 2 latest firmware
    Firmware installation
    783
    • peirof
      peirof last edited by
      i dont connect to forums time ago...
      i have instaled
      Board: Duet WiFi 1.02
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC4 (2019-10--9b1)
      Duet WiFi Server Version: 1.23
      with the crisis of Coronavirus, now I am more at home ... that I can dedicate to the printer ...
      The issue is, the first thing I want is to update the firmware, since I haven't touched it in a while.
      The current one, I think it is 2.05.1, but I am not sure, because I have read that there is a version, beta, 3.xx.
      What firmware do you recommend installing?
      Another thing is to adjust / configure my Zprobe, a Precision Piezo.
      In 95% of the points, its operation is correct, but in that 5% it usually fails, detecting false positives
      I have it config.g
      M558 P8 I1 R0.9 F150 Z1; set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z2.5; set Z probe trigger value, offset and trigger height
      • A Former User
        A Former User last edited by
        2.05.1 is the latest of the version 2 of the firmware.
        version 3 brings more features, and is availbale as 3.0 release and newer release candidates - unless you specifically need features offered by RRF3 I'd go with 2.05.1 as the configuration changes to RRF3 can be non-trivial and there are imo still a few kinks to iron out of RRF3.
        as always read the whats new files before updating.
        peirof 1 Reply Last reply Reply Quote 0
        • bondus
          bondus last edited by
          If you are getting too many false positive on the piezo you could try to back off the sensitivity resistor a bit. Be careful, that little potentiometer is fragile.
          With the old kind with a separate piezo element it is a bit of an art to tighten the screws to get the right squeeze on the piezo. The Orion is a lot easier to use.
          The Z parameter to G31 looks way off. For a probe that senses with the nozzle it should be very close to 0 (zero). I run with Z-0.1.
          And the Precision Piezo likes fairly high probing speed. I use F600 for M558.
          • peirof
            peirof @Guest last edited by
            @bearer
            Thanks, for the moment rest in version 2.... i have updated to 2.05.01.
            Do you know if support for version 2, will be dropped?
            • peirof
              peirof @bondus last edited by peirof
              @bondus
              Thanks too,
              for the moment its working, no false positives. Now i have:
              M558 P8 I1 R0.9 F600 Z1; set Z probe type to effector and the dive height + speeds
              G31 P500 X0 Y0 Z-0.1; set Z probe trigger value, offset and trigger height
              The results
              COMPENSATION
              Number of points: 25
              Probing radius: 75 mm
              Probe area: 176.7 cm²
              Maximum deviations: -0.352 / 0.138 mm
              Mean error: -0.060 mm
                Phaedrux Moderator @peirof last edited by
                @peirof said in Duet 2 latest firmware:
                The bulk of development going forward will be on RRF3. RRF2 may get some bug fixes if anything big comes up, but no new features.
                For the time being, it's probably best to stick with 2.05.1
                Mogal 1 Reply Last reply Reply Quote 1
                • Mogal
                  Mogal @Phaedrux last edited by
                  Just wondering if 2.05.1 is still the firmware to stick to?
                  Currently here:
                  Board: Duet WiFi 1.02 or later
                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
                    @Mogal Things have progressed a great deal since then and RRF3 is the way to go.
                    If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                    That will get your firmware and DWC up to date.
                    For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3 and re-add any customizations you may have.
                    https://configtool.reprapfirmware.org/Start
                    • Mogal
                      Mogal last edited by
                      Thanks, is it really that easy? I thought I read there where some big changes that needed to be done? I'll look into it a little more while I download and wait for the printer to finish printing it's 12hour print!
                        Phaedrux Moderator @Mogal last edited by
                        @Mogal well if you generate a new config all of the changes are done for you. Any custom things would need to be redone manually, but it gives you a good starting point.
                        • PeterA
                          PeterA last edited by
                          I have the same setup as you and (duet Wifi) and a Piezo. Just did the upgrade to the 3.2. Had some minor issues (mainly the piezo command) that the guys here helped me out with. I like the new web interface but all in all relatively painless. had to go to v3 then to v3.2 to get it to work.
