    Cancel individual objects on the build plate
    Beta Firmware
    8
    26
    3.3k
    • PCRundefined
      PCR
      @dc42 any news? I had the possibility in RepetierServer to cancel a object. Was quite nice.
        This was waiting for the plugin interface in DWC. That interface has been implemented in DWC 3.2beta1. Now the plugin for object cancellation just needs to be written.
        • ppaukstelisundefined
          ppaukstelis
          Just wanted to add that as the person that originally developed the octoprint plugin and did the initial work for Marlin, I really appreciate the systematic way this has been approached in RRF and documented in this thread. Well done. Now, to "standardize" where to put those object labels relative to wipes/retractions....
          T3P3Tonyundefined 1 Reply Last reply Reply Quote 3
          • T3P3Tonyundefined
            T3P3Tony administrators @ppaukstelis
            @ppaukstelis thanks for the feedback. The model used for changing tools may also be useful here for slicer writers. i.e:
            gcode that happens before the object starts to be printed on that layer,
            gcode that happens after that layer of the object finishes being printed
            Than can the be tagged with ";Pre-ObjectX" and ";Post-ObjectX"
            Anything in between a "post-ObjectX and a "pre-ObjectY" is not object related (i.e its travel, or a tool change, or a prime etc).
            would that work?
            www.duet3d.com
              ppaukstelis
              I was thinking more in terms of what a slicer considers to be an object. Right now PrusaSlicer/SuperSlicer already have "; stop printing objectX" tags that can be used for termination as you suggest. But as of right now post-object wipes are not considered part of the object, they come after the stop printing comments. This wastes time and movement. Cura uses NONMESH object tags which work fine. However, it defines all supports as NONMESH and not as parts of objects, so you can never cancel the supports along with the individual object.
              • T3P3Tonyundefined
                @ppaukstelis ahh I see, just more granularity required in tagging really
                www.duet3d.com
