    What is the latest firmware version for Duet 2 Wifi
    Firmware installation
    9
    14
    1993
    • AdrAs
      AdrAs last edited by
      Yesterday I upgraded the firmware of my Duet 2 Wifi.
      I'm still a little bit confused if I picked the most recent version of all files.
      My WebInterface reports:
      Firmware Version: 2.05.1 (2020-02-09b1)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      Is this the most up to date version of all components?
      • A Former User
        A Former User last edited by
        there was a thread just like so the other day, it may help https://forum.duet3d.com/topic/15092/duet-2-latest-firmware/
        • AdrAs
          AdrAs last edited by AdrAs
          @AdrAs said in What is the latest firmware version for Duet 2 Wifi:
          rsion: 2.05.
          Thanks, looks like I'm up to date. I'm still wondering where I can get the Version 3.0 firmware. Because I flashed the DuetWifiCombined.bin file from Release 3.01-RC4
          I'm currently converting my Anycubic Predator to my Duet 2 Wifi board. That's quite a lot of work. And since there seem to be quite some configuration changes from version 2.X to version 3.x I'd prefer to install 3.x right away.
          [Edit] Or is version 3.x only for Duet 3 boards?
          A Former User droftarts 2 Replies Last reply Reply Quote 0
          • aidar
            aidar last edited by
            https://github.com/dc42/RepRapFirmware/releases
            However, with Duet2 board i would stay with 2.05.1 firmware. Just my preference...
            • A Former User
              A Former User @AdrAs last edited by
              No, you can use RRF3 with Duet 2 boards as well (without the single board computer the Duet 3 board has optional support for)
              • Dougal1957
                Dougal1957 last edited by
                But you can't go straight to V3.01 you have to go to V3.0 first but be aware going from V2.x to V3.x has a lot of configuration changes to make.
                  My recommendation is that anyone using Duet 2 who does not need the facilities of RRF3 stay on 2.05.1 for now, until 3.01 is released.
                  • droftarts
                    droftarts administrators @AdrAs last edited by
                    @AdrAs You need to update to the 3.0 release first , then to the latest 3.01-RC4. Or erase the firmware and use Bossa to update the firmware directly.
                    From https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-301beta1
                    You cannot upgrade a Duet WiFi, Ethernet or Maestro direct to this release from RRF 1.x or 2.x because the firmware binary is too large for the old IAP. You must upgrade to version 3.0 first, then from 3.0 you can upgrade to this release.
                    Also, if you're upgrading from a working RRF 2.x setup, you will need to make substantial changes to your config.g file. Or use the RRF config tool to make a new one.
                    • AdrAs
                      Alright, I'll stick to 2.05.1. Version 3 changes don't seem to be important by now. Thanks for your help everyone!
                      • peirof
                        peirof last edited by
                        hi,
                        i am interested in this post too. Interested in upgrade to version 3, of firmware... but i will wait until 3.01 has released...
                        Something useful, it will be an upgrade V2 to V3 guide in WiKi.... How to flash, config changes, gcode changes...
                        Think there are some similar in a post....
                          I've added instructions for that at https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware?revisionid=HEAD#Section_Special_considerations_for_upgrading_between_particular_firmware_versions.
                          peirof Stephen6309 2 Replies Last reply Reply Quote 0
                          • peirof
                            peirof @dc42 last edited by
                            @dc42 perfect... I was waiting something like these...
                            • Stephen6309
                              Stephen6309 @dc42 last edited by
                              @dc42 https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware?revisionid=HEAD#Section_Upgrading_a_Duet_WiFi_Ethernet_Maestro_from_firmware_2_x_to_3_01_or_later has a bad link.
                                Phaedrux Moderator @Stephen6309 last edited by
                                @Stephen6309 Which one?
