    how do you setup multi probe points?
    • Borgtribble
      Borgtribble last edited by
      I'm running Duet 2 1.04 wifi with Bltouch on an ender 3.
      So my current bed.g has 4 points setup like so
      ; Probe the bed at 4 points
      G30 P0 X50 Y50 H0 Z-99999 ;G30 P0 X20 Y20 H0 Z-99999
      G30 P1 X50 Y185 H0 Z-99999 ;G30 P1 X20 Y215 H0 Z-99999
      G30 P2 X185 Y185 H0 Z-99999 ;G30 P2 X215 Y215 H0 Z-99999
      G30 P3 X185 Y50 H0 Z-99999 S ;G30 P3 X215 Y20 H0 Z-99999 S
      M98 Pretractprobe.g ; retract mechanical Z probe
      how would I expand this to 16 points?
      Also on a side note the does the bed mesh limits axis limits seem right in the config.g for the ender 3?
      M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
      M208 X258.5 Y246 Z260 S0 ; Set axis maxima
      M557 X50:185 Y50:185 S65 ; Define mesh grid
      • Borgtribble
        SO after some reading the line ((M557 X50:185 Y50:185 S65 ; Define mesh grid )) The S65 means the machine will sample 65 points from mesh grid?
        • aidar
          aidar last edited by
          Your bed.g has nothing to do with mesh probing. Bed.g is called by G32, but i assume you use G29 for mesh probing. So M557 comes in play here. S parameter (in your case 65) means probe points spacing, or let say measurement between probe points. So if you want more points, set it for example 20 or so.
          • zapta
            zapta last edited by
            The S parameter is the sample intervals in mm. In your case, your X and Y ranges are 50 to 185 (135mm intervals) so for example a spacing of 27mm will result in 5 x 5 sampling grid.
            • Borgtribble
              Borgtribble last edited by Borgtribble
              Thanks for the info however something is off. When I run the G29 S0 the hotend will move right taking samples and continue off the bed. Why is it doing this?
                Please have a look at this: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
