    cant level bed z probe not triggered during probing move
    • xbrmxjamieundefined
      xbrmxjamie
      im not using a z probe im using ezabl from my cr10 on my tronxy x5sa400 with duet wifi board on 2.05 firmwire
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 27 2020 20:54:16 GMT+0000 (Greenwich Mean Time)
      M550 P"Tronxy x5sa 400" ; set printer name
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z400.00 E98.00 ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z400 S0 ; set axis maxima
      M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
      M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-35 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:385 Y15:385 S40 ; define mesh grid
      M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        Does it work when you test it like this?
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        When exactly do you get the error?
          xbrmxjamie
          it works till i hit G30 S-1 homing works
            I'm not really familiar with ezabl. What kind of probe is it and how do you have it connected?
              xbrmxjamie
              its connected to z end stop and is either a inductive or capacitive sensor but has external power source
              https://www.th3dstudio.com/product/ezabl-pro-plug-print-auto-bed-leveling-kit/
              i have older model
                Take a look through previous forum posts on the ezabl.
                https://forum.duet3d.com/search?term=ezabl&in=titlesposts&matchWords=all&sortBy=relevance&sortDirection=desc&showAs=posts
                  xbrmxjamie
                  thanks for your help think i found my answer here i think gonna check to see if i have polarity wrong https://forum.duet3d.com/topic/8771/ezabl-mini-direct-connect-z-probe-from-th3d/4
                  will check it out tomorrow as it late
