    Is this Repairable?
    • BMMalundefined
      BMMal
      While installing Mechaduinos on my machine, I needed to supply them with 5V. My intent was to get this off of the 5V pin for the PanelDue. Unfortunately, I mixed up the Vin and 5V on the Mechaduino end resulting in connecting 24V into the 5V power system of the Duet WiFi… Not a good day. Now the heaters are stuck on and I cannot connect to the board. I'm wondering if there is any saving this or should I just cut my losses and get a new one?
      This appears to have damaged my Duex5 as well.
      Duet Ethernet - Most likely the most recent Edge firmware
      Duet X5
      7" Panel Due V2
      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
      • W3DRKundefined
        W3DRK
        I repaired a Duet WiFi that succumbed to the same fate and it needed practically every 5V device including the MCU and WiFi module replaced. Unfortunately, if I were to charge for that repair it would approach the same cost as just replacing the board…
        • raykholoundefined
          raykholo
          @BMMal may I ask where you are located, and what you ended up doing?
          And @W3DRK, I sent you a PM, I have read that you sometimes have difficulty receiving messages on this forum, so please check.
          Thank you,
          Ray
