Duet 2 wifi - Problems with mesh leveling
  • Hello,
    I am manually bed leveling my delta printer cause i found out my bltouch was kinda faulty.
    After a first try print i was happy with the first layer.
    But when i started a second print the 1st layer was really not the same as before.
    I dont know what can i set up to repeately have consistent prints.
    Hope someone can help me.
  • I found that editing this line in my config.g file improved my bltouch repeatability
    M558 P9 H5 F210 T6000 A50 S0.005 ; Set Z probe type to bltouch and the dive height + speeds
    Annn Maximum number of times to probe each point, default 1. Maximum, as of 2.03, is 31. Setting M558 A parameter to anything >31 set it to 0 instead of to 31
    Snnn Tolerance when probing multiple times, default 0.03mm
    I just set Ann really high but it only probes 2-4 times until it gets it right.
    Hope that helps you
    Edit:I guess after updateing I need to go down to Ann <31 after reading that copy and paste
  • Moderator
    @Cresty Please see this post for the information we need to be able to help you: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
