Duet 2 Ethernet - problem with DWC
I dumped the DHCP and forced the mask to 255.255.255.0 and now the thing seems to be working!
The only change that has happened between now and the last time I used the Duet is a Mac OS update so I guess something got messed up then.
I'm quite bad with computers and networks so Thanks a million!
What other options do you have for
Ah, too late, but you got it.
@bearer said in Duet 2 Ethernet - problem with DWC:
"Manually" with mask 255.255.255.0 worked.
yeah, i just didn't see your previous response while writing that question. all good!
