    Wiring a toolboard to the Duet3 mainboard.
    • Nuramori
      Nuramori last edited by Nuramori
      I'm looking to make the connectors for this, but it's not exactly clear what wires correspond to what between the two. The diagram for the mainboard has for the CAN-FD connectors labeled as CAN1_h and CAN0_h for instance, but the toolboard connection doesn't have the same designation to know the pairs or how I would pair them between the two endpoints. I could infer from the tool distribution board (which I'm not using or need), but I wanted to be sure so I don't fry anything.
      • A Former User
        A Former User last edited by
        Main board have two can busses, 0 and 1. toolboard only have the one can bus, but 4 connections so you can wire it in a chain. Effectively you use Can bus 1 ffom the main board, and match up the H and L signals to your toolboard then terminate the unused pins.
        See if this post from dc42 helps; https://forum.duet3d.com/topic/14469/duet-3-tool-board/8
        Nuramori 1 Reply Last reply Reply Quote 1
        • Nuramori
          Perfect. The link cleared it up for me. Good thing I saw that, as I'd not have put a resistor in.
          • Nuramori
            Nuramori @Guest last edited by
            @bearer would 20awg wire be adequate to power the toolboard, or should it be a thicker wire? I'll be supplying 24v.
