    Bed leveling Anycubic Predator Delta
    968
    • gpermanundefined
      gperman
      I'm stumped on this.
      I upgraded recently to RRF3.0. Applied all of my parameters to the RRF configtool:
      I run auto calibration and the z probe isnt diving and delivers Error: Z-probe already triggered at start of probing move.
      I'm using the original anycubic predator microswitch z-probe.
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 03 2020 13:10:48 GMT-0400 (Eastern Daylight Time)
      M550 P"Anycubic Predator"                          ; set printer name
      M665 R225 L440 B177 H452.25                      ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                                      ; put your endstop adjustments here, or let auto calibration find them
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z80.00 E663.00                   ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00           ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00           ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M208 Z0 S1                                         ; set minimum Z
      M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                                ; configure active-high endstop for high end on Z via pin zstop
      M558 P5 C"zprobe.in+zprobe.mod" H5 F120 T6000      ; set Z probe type to switch and the dive height + speeds
      M558 H30                                           ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X0 Y0 Z16.95                              ; set Z probe trigger value, offset and trigger height
      M557 R160 S20                                      ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y169.9 H0 Z-99999
      G30 P1 X147.14 Y84.95 H0 Z-99999
      G30 P2 X147.14 Y-84.95 H0 Z-99999
      G30 P3 X0 Y-169.9 H0 Z-99999
      G30 P4 X-147.14 Y-84.95 H0 Z-99999
      G30 P5 X-147.14 Y84.95 H0 Z-99999
      G30 P6 X0 Y84.9 H0 Z-99999
      G30 P7 X73.53 Y42.45 H0 Z-99999
      G30 P8 X73.53 Y-42.45 H0 Z-99999
      G30 P9 X0 Y-84.9 H0 Z-99999
      G30 P10 X-73.53 Y-42.45 H0 Z-99999
      G30 P11 X-73.53 Y42.45 H0 Z-99999
      G30 P12 X0 Y0 H0 Z-99999 S6
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
        Phaedrux Moderator @gperman
        @gperman said in Bed leveling Anycubic Predator Delta:
        I think you may need to invert the probe signal pin. Which I think in your case would be
        M558 P5 C"!zprobe.in+zprobe.mod" H5 F120 T6000
        • gpermanundefined
          gperman
          inverting the probe signal worked to make the effector dive but it kept diving well after the probe triggered and kept going. Had to perform an emergency shutoff.
          Now to figure out why the steppers didn't cut off after the probe triggered.
          I tested the probe, it passes a continuity test and shows to be normally closed and is connected to e0 as per the config tool's instructions.
          perhaps the extra M558 command is messing something up. Going to remove and try again.
          gpermanundefined 1 Reply Last reply Reply Quote 0
          • gpermanundefined
            gperman @gperman
            Removing M558 H30 did not solve the issue.
            I am currently running g29 and triggering the probe prematurely to see if it stops the carriage which it does not. Otherwise, I believe it would continue on and crash into the bed. I would not like to find that out the hard way.
            Can someone define or walk me through how to actually level a bed using an Anycubic Predator microswitch Z probe?
            I assume the main function for determine the level of the bed is g29 which appears in the dropdown menu of Auto Calibration.
            I have tried multiple codes in the config m558 P4, P5, C"e0stop", C3...
            on duet web control the e0 endstop hit shows no change. The z probe stays at 1000, no change.
            Tested the switch through the harness all the way to the connector that shows normally closed still and switching when pressed. Plus the e0 LED blinks when the switch is pressed. It's just not recognized in the software.
              Is that a probe that you have to attach to the print head before using it?
              • gpermanundefined
                gperman @Phaedrux
                @Phaedrux yes.
                Also, i got the probe to recognize and change values in the interface by depinning and connecting it to the z probe connector on the board instead of e0.
                It starts at 0 and displays 1000 when triggered.
                Have not seen an effect on anything from adding ! As suggested.
                I need to try and see if the single z probe g code command works. I’m going to have to risk it potentially ramming into the bed i guess.
                Triggering the z probe whilst manually jogging the axes down does not stop the effector which is not encouraging.
                Ran G32 which did not touch the bed. Perhaps i am misunderstanding "probing." does the effector just glide along the bed? It doesn't stop at each point, dive down until the probe triggers then rise again like it did on the factory firmware/board.
                I assumed setting up the config tool using a microswitch would result in a behavior similar to the factory setup.
                I lowered G31 Z16.95 to Z12. The probe touches the bed now but I get an Error: Z probe already triggered at start of probing move.
                • gpermanundefined
                  gperman
                  Yea, still havent figured this out. Ran bed.g as a macro, ran G29, G30, G31, G32. The probe just moves around to the XY coordinates but doesnt stop, doesnt dive, doesnt probe.
                  I have no idea why.
                    Is the switch normally open or normally closed?
                    Do you have it connected to the in and ground terminals of the z probe connector?
                    Use, M558 P5 C"zprobe.in" H5 F120 T6000
                    I don't think you need the modulation pin because this isn't an analogue probe.
                    gpermanundefined 2 Replies Last reply Reply Quote 0
                    • gpermanundefined
                      gperman @Phaedrux
                      @Phaedrux i have it connected to the zprobe.in pin and zprobe.mod pin. It is a normally closed digital microswitch.
                        I'm just going from this: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mode_Num_5
                        • gpermanundefined
                          gperman @Phaedrux
                          @Phaedrux said in Bed leveling Anycubic Predator Delta:
                          YES! This solved it! Thank you so much. This was a huge headache.
                          Removing the zprobe.mod allowed it to recognize as a digital switch instead of analogue and now it probes.
                            Glad that worked. I think the issue is that the configurator has the zmod pin selected by default and it's not easy to know beforehand what it is and why it's selected and that you should actually unassign it.
                            I think I'm going to suggest that it is unassigned by default in the configurator.
                            • gpermanundefined
                              gperman
                              Or selectable by a check box in the z probe section under endstops.
