    Part cooling fan not working.
    Firmware installation
    843
    • SoDamnInsaneundefined
      SoDamnInsane
      My part cooling fan no longer switches on.
      The cabling is okay, because if I put it on the ALWAYS ON pin, it just runs.
      Now I'm not sure if I accidentally used another config.
      These are my current settings.
      **As advised by Duet3D, they are connected as follows:
      The part cooling fan on FAN0 pins on Duet2 Wifi board
      The extruder fan is on FAN1 pins on Duet2 Wifi board**
      Here my relevant config.g settings
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B3950      ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S290                                       ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                    ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
        I assume you're trying to turn it on by sending M106 P0 S1?
        Have you recently changed anything else like updating the firmware? When did it last work?
        SoDamnInsaneundefined 1 Reply Last reply Reply Quote 0
          SoDamnInsane @Phaedrux
          @Phaedrux said in Part cooling fan not working.:
          Thx for your quick answer.
          I've tried to update the firmware, but I got a error. So I'll look at that later.
          And after this I've this issue... Thanks for the reminder. I forgot that.. 😞
            SoDamnInsane
            UPDATE
            I've just followed this Fallback procedure. https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
            No results.... 😞
              SoDamnInsane
              Now it gets even stranger.
              The extrusion control is now blended out.
              The tools are active...Now it gets even stranger.
                Can you send M115 in the gcode console and report back the version?
                Can you answer my original questions?
                  SoDamnInsane @SoDamnInsane
                  @SoDamnInsane said in Part cooling fan not working.:
                  @Phaedrux I think I already answered it, lol.
                  This is the response of the M115 command:
                    SoDamnInsane
                    UPDATE
                    Problem solved.
                    I went back to a previous version of the RRF 3 firmware version.
                    But now have 3 fans in my DWC interface, LOL. 😂
                    I only need the FAN 1, that's my part cooling fan.
                    Can i change this?
                    And the Extrusion Control is still blend out.... 😞
                    Thanks in advance!
                      droftarts administrators @SoDamnInsane
                      If you’re using DWC 2.1.0, it’s a known issue. Revert to 2.0.7.
                      Tool fan and fan 1 are the same fan. You can change fan visibility in Machine configuration. Thermostatic fans are hidden.
                      SoDamnInsaneundefined 3 Replies Last reply Reply Quote 0
                        SoDamnInsane @droftarts
                        @droftarts said in Part cooling fan not working.:
                        Thx. for the quick response!!
                        I'm using DWC 2.1.0 indeed. I revert back to 2.0.4, but then only 1 fan was vissible, lol.
                        I change it right now to 2.0.7.
                        I have the tool fan connected on the ALWAYS ON pins..
                          This post is deleted!
                            I just installed DWC 2.0.7.
                            But now Only the Tool Fan and Fan 0 are shown.
                            So now I can't control my part cooling fan anymore... (Sorry, I'm still a beginner with Duet)
                            BUT... Now it's possible to use the Extrusion Control.. 🤔 🤔
                               ; Fans        M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency        M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off        M950 F1 C"fan1" Q500                                    ; create fan 1 on pin fan1 and set its frequency        M106 P1 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
                              You haven’t shown your tool definitions, so I don’t know which one you have as a hot end fan, and which is a part cooling fan. Generally, F0 should be your part cooling fan, and not bound to a tool. F1 should be the hot end fan. This is because most slicers only need to control the part cooling fan, and usually do it with plain M106 commands.
                              So your F0 fan should be the part cooling fan, should not be assigned to a tool, and should not be set to thermostatic control. Then it will always be visible and controllable in DWC.
                              Your F1 fan should be the hot end fan, should be assigned to the tool, and should be thermostatically controlled or always on. Thermostatically controlled fans are usually hidden in DWC, as you can’t override them, so so long as they’re working, you don’t need to see them. If it’s not thermostatically controlled, it will be hidden until the tool is enabled.
                              At least, that’s how it’s worked in the past, though sounds like DWC 2.1.0 may have changed default visibility.
                                @SoDamnInsane DWC has been fixed, see https://forum.duet3d.com/topic/15342/duet-web-control-2-1-1-released
                                  Thx @droftarts
                                  This is how the settings are right now!
                                    @SoDamnInsane post your tool definition too.
                                      SoDamnInsane
                                      Thx for the link of the DWC 2.1.1 update, @droftarts
                                      The Extrusion Control is now working.
