    Solved Difference between M28 and manual upload of Gcode
    Duet Web Control
    361
    • JBisc
      JBisc last edited by JBisc
      Hey evrybody
      I am currently facing the problem, that there is a different behaviour by using M28 or using manually upload of a Gcode file over Duet Web Control
      if I use M28 (by M28 "0:/gcodes/name.gc")), some commands of my uploaded file are deleted:
      for example all command G4 P100 are deleted.
      If I am using the some file and manually upload it, it does not happen.
      Do you guys habe any idea? I am running out of ideas.
      Newest firmware used.
      My Setup: Duet 3 MB6HC Main Board with attached RPI
        @lepetitmort said in Difference between M28 and manual upload of Gcode:
        Please be specific. What version of firmware and DWC are you using. And what board?
        • JBisc
          @Phaedrux said in Difference between M28 and manual upload of Gcode:
          Duet Web Control 2.0.7
          Duet 3 Main Board 6HC
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
            Thanks, that's helpful. I'm not sure if this is intended/expected or not. That will be for @dc42
              Uploading files using M28 should not remove any command lines. However, AFAIR it does remove comments. Are you certain that your G4 lines are not commented out with a semicolon at the start?
              • JBisc
                Yes I am sure that nothing is commeted out.
                Here is an example:
                If i send the following gcode
                M106 S1.0
                G4 P25
                ;M106 S1.0
                M106 S0.0
                M106 S1.0
                M106 S255
                M106 S1.0
                G00 Z0.000000
                G00 X105.324704 Y211.976535
                M106 S1.0
                G01 Z0.000000 F100.0(Penetrate)
                the final file on the duet looks like
                G4 P25
                ;M106 S1.0
                G0 Z0.000000
                G0 X105.324704 Y211.976535
                G1 Z0.000000 F100.0;Penetrate
                I am not understanding what is happening here.
                  Are you running your Duet 3 in standalone mode or with an attached RPi?
                  JBisc 1 Reply Last reply Reply Quote 0
                  • JBisc
                    JBisc @dc42 last edited by
                    @dc42 Attached RPI on which a python script sends the commands.
                      dc42 administrators @JBisc last edited by
                      I'll ask @chrishamm to take a look at this.
                      • JBisc
                        @dc42 Great thanks a lot!
                        • chrishamm
                          chrishamm administrators last edited by
                          Thanks for reporting this, I've got a fix ready that will be published as part of DSF 1.3.2.
                          Duet software engineer
