Solved G32 not working after FW upgrade to 3.00
HI,
i have a strange problem. i upgraded to FW 3.00 on my Dued3d Wifi and amended all config files.
Everything is working fine except one thing. G32 is running but not ajusting my 2 lead screws any longer.
Its just running but not doing anything.
Those are the entries in my config.g which were working with FW 2.5 without any problems.M584 X0 Y1 Z2:4 E3
M671 X-65:362 Y151:151 S3did i missed to update something somewhere?
thanks for any tips
Matt
Can you post your entire config.g and bed.g? homeall.g as well.
Thats my config files.
config.g
0:/sys/config.g ; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300 ; General preferences M80 ; Turns on the ATX power supply G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M667 S1 ; Select CoreXY mode ; Network M550 PBLV mgn Cube ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes backwards blv: its was S1 M569 P1 S1 ; Drive 1 goes backwards blv: its was S1 M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes backwards WAS 0 M569 P4 S0 ; Drive 2 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation ;M92 X200 Y200 Z400 E414,9 ; Set steps per mm for Bondtech. M92 X200 Y200 Z400 E409,98 ; Set steps per mm for Bondtech. M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (Jerk) (mm/min) M203 X20000 Y20000 Z600 E2000 ; Set maximum speeds (mm/min) M201 X500 Y500 Z100 E5000 ; Set accelerations (mm/s^2) M906 X1600 Y1600 Z1600 E700 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ;Drive Mapping M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 M671 X-65:362 Y151:151 S3 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis ; Pressure advance ; M572 D0 S0.05 ; disabled Pressure advance ;Retract ;M207 S1.0 F2400 Z0.075 ;M207 S1.0 F2400 Z0 ; Axis Limits M208 X-23 Y0 Z0 S1 ; Set axis minima M208 X300 Y331 Z340 S0 ; Set axis maxima ; Endstops M574 X1 S1 P"xstop" ; Set active high endstops edit: Y endstop is high(max). M574 Y2 S1 P"ystop" ; Set active high endstops edit: Y endstop is high(max). ;M574 Z1 S2 P"zstop" ; Define Z to use Probe. Home to Min ; Filament sensor ;M591 D0 P1 C3 S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0) ; BLTouch - Heaters ; M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board. M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater ; Z-Probe M574 Z1 S2 P"zstop" ; Set endstops controlled by probe M307 H1 A687.7 C212.3 D8.0 V24.1 B0 ; Set PID for hotend values M307 H0 A246.4 C522.8 D1.0 V23.7 B0 ; Set PID for heated bed values M558 P9 C"^zprobe.in" H5 F500 T4000 ; Set Z probe type BLTouch sensor M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector G31 P25 X28.5 Y-5 Z2.37 ; Set Z probe trigger value, offset and trigger height M557 X30:270 Y30:270 S80 ; Define mesh grid ; Heaters and Sensors ;M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0 M143 H0 S130 ; Set temperature limit for heater 0 to 100C ;M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M308 S1 P"e0_temp" Y"thermistor" T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1 M143 H1 S270 ; Set temperature limit for heater 1 to 260C ; Fans M950 F0 C"FAN0" Q500 M106 P0 S0 H-1 C"Part" ; Cooling-Fan,, Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M950 F1 C"FAN1" Q500 M106 P1 S1 H1 T35 C"Tool" ; Tool-Fan, Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M950 F2 C"FAN2" Q500 M106 P2 S1 H-1 C"Duet" ; Duet-Fan, Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Automatic power saving M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss ; Custom settings are not configured M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
bed.g
0:/sys/bed.g ; bed.g ; called to perform automatic bed compensation via G32 ; G28 ; home ;M401 ; deploy Z probe (omit if using bltouch) G30 P0 X5 Y151 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X295 Y151 Z-99999 H2 ; probe near a leadscrew and calibrate 2 motors M402 ; retract probe (omit if using bltouch)
homeall.g
0:/sys/homeall.g ; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300 G91 ; relative positioning G1 Z5 F6000 H2 ; lift Z relative to current position G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-355 ; home X axis G1 H1 Y355 ; home Y axis G1 X5 Y-5 F6000 ; go back a few mm G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y355 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X121,5 Y156 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed G30 ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 H2 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
You have a "H" parameter in your G30 (bed.g)
Not sure why you'd have different probe offsets on a CoreXY
I think it should be S2 -
@OwenD said in G32 not working after FW upgrade to 3.00:
I think it should be S2That was it, thanks a lot.
Must have replaced one "S" to much during the config change.but what do you mean with different probe offsets?
See the notes on the H parameter
https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
ahh Ok, actually i had no "H" in my G30, was a replacement mistake. suppose to be "S"
now all is working again
thanks a lot.
