    Failed to update DuetWifiServer
    Firmware installation
    884
    • vucheriaundefined
      vucheria
      Help!
      I usually find the solutions in the forums without the need to ask for help..but after full day of searching and trial and error I give up.
      When I was trying to update the firmware from 2.03 to 2.05.1 I've noticed that my DuetWifiServer version was 1.21 but I've proceeded to install the Duet2CombinedFirmware DuetWifiServer DuetWebControl 2.0.7..everything updated only the DuetWifiServer version remained 1.21
      I know that the correct DuetWifiServer version for 2.03 firmware should have been 1.23 in the first place
      I've tried fallback procedures 1, 2 Installing_and_Updating_Firmware
      The error that I get is when I use YAT with M997 S1 is
      Trying to connect at 230400 baud: failed
      Trying to connect at 115200 baud: failed
      Trying to connect at 74880 baud: failed
      Trying to connect at 9600 baud: failed
      Error: Installation failed due to comm write error
      I've also tried other suggestions offered in other posts with the same error but no success:
      https://forum.duet3d.com/topic/13122/duetwifiserver-upgrade-failed-failed-due-to-comm-write-error
      https://forum.duet3d.com/topic/3147/think-wifi-dont-work/18
      https://forum.duet3d.com/topic/766/new-board-can-t-update-wifi-firmware/9
      also tried to downgrade to 1.21 firmware and update from there to newer versions..still nothing
      By the way the Duet Board v1.04 works just fine, I can connect to wiFi via web interface, I can connect from USB, I can print, etc.. but I cannot update DuetWifiServer.
      Any suggestions / ideas? It is a hardware problem?
      Thanks
      • A Former User?
        A Former User
        Random shot in the dark;
        start without SD card, insert SD card and run M21 M111 P14 S1 M997 S1
        (and M552 S1 after the update success or failure)
        vucheriaundefined 1 Reply Last reply Reply Quote 0
        • vucheriaundefined
          vucheria @A Former User
          @bearer
          The same..
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
          ok
          SDHC card mounted in slot 0, capacity 3.98Gb
          ok
          Debugging enabled for modules: WiFi(14)
          Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
          ok
          ok
          M997 S1
          ok
            Have you seen this? https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_2_WiFi
            • vucheriaundefined
              vucheria @Phaedrux
              @Phaedrux
              Yes, followed the instructions as in the link...step by step..same error
              I’ve also downgraded the firmware to 1.21 and tried to update to 2.02 with the DuetWiFiServer 1.22 and 1.23...same error; and also tried with all major releases
              I will try again in the morning maybe I’ve missed something
              Anyway thank you guys for support!
                Sorry I missed that you included that link in your first post.
                What should work is if you have 2.05.1 already installed with DWC 2.0.7 in the /www folder, and the M552 command commented out in your config file, and you have the 1.23 wifi server bin file on the SD card you should be able to send the wifi server update command to initialize the update.
                So the one thing you haven't mentioned doing is the commenting out of the M552 command. Have you done that?
                If you have commented it out, have you tried sending any other M552 S commands over yat?
                M552 S-1 to disable the wifi module
                M552 S0 to disable networking
                M552 S1 to enable networking
                A Former User? vucheriaundefined 2 Replies Last reply Reply Quote 0
                • A Former User?
                  A Former User @Phaedrux
                  @Phaedrux said in Failed to update DuetWifiServer:
                  wouldn't starting the Duet without the SD inserted sort of achieve that? that was my thinking at least to rule out any conflicting config, mount the SD card and then update.
                  • vucheriaundefined
                    vucheria @Phaedrux
                    @Phaedrux
                    I've tried yesterday this aproach and also tried again today with M552 commented and all M552 variants..no success,
                    I've also tried as suggested by @dc42 in other posts with and without VIN power, without endstops connected or BL-Touch
                    When I use the M997 S1 the wifi led blinks as if starting up but after a few seconds it is turning off.
                    please see below today's log from YAT
                    M115
                    M552
                    WiFi module is disabled
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                    Board ID: 08DGM-917NK-F23T0-6JKDL-3S86R-KWBDF
                    Used output buffers: 1 of 24 (1 max)
                    Static ram: 25712
                    Dynamic ram: 93160 of which 396 recycled
                    Exception stack ram used: 312
                    Never used ram: 11492
                    Tasks: NETWORK(ready,1360) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 00:05:06 ago, cause: power up
                    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 12300 bytes (slot 1)
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 36.4, current 41.9, max 42.1
                    Supply voltage: min 24.3, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                    Cache data hit count 606309682
                    Slowest loop: 1.67ms; fastest: 0.07ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                    === DDARing ===
                    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is ready with "M122" in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 1001.18ms; fastest: 0.00ms
                    HTTP sessions: 0 of 8
                    • WiFi -
                      Network state is disabled
                      Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                    M997 S1
                    M997 S0
                    M115
                    M552
                    M552 S0
                    WiFi module started
                    M997 S1
                    M552 S-1
                    M552
                    M552 S1
                    WiFi module started
                    WiFi module is connected to access point v2.4GhzE, IP address 192.168.0.108
                    M997 S1
                    my config file
                    ; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 11 2018 03:52:52 GMT+0200 (Eastern European Standard Time)
                    G90                                                ; Send absolute coordinates...
                    M555 P1 					   ; speak the firmware
                    M667 S1                                            ; Select CoreXY mode
                    M550 P"hypercubeEvo"                                ; Set machine name
                    ;M552 S1                                            ; Enable network
                    M586 P0 S1                                         ; Enable HTTP
                    M586 P1 S0                                         ; Disable FTP
                    M586 P2 S0                                         ; Disable Telnet
                    M569 P0 S1                                         ; Drive 0 goes forwards
                    M569 P1 S1                                         ; Drive 1 goes forwards
                    M569 P2 S1                                         ; Drive 2 goes forwards
                    M569 P3 S0                                         ; Drive 3 goes forwards
                    M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E521                  ; Set steps per mm
                    M566 X1000.00 Y1000.00 Z150 E1000                 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z300.00 E700            ; Set maximum speeds (mm/min)
                    M201 X4000.00 Y4000.00 Z250.00 E4000                ; Set accelerations (mm/s^2)
                    M906 X960.00 Y960.00 Z960.00 E1000.00 I30           ; Set motor currents (mA) and motor idle factor in per cent
                    M208 X0 Y0 Z0 S1                                   ; Set axis minima
                    M208 X285 Y285 Z270 S0                             ; Set axis maxima
                    M574 X2 Y2 S1                                      ; Set active high endstops
                    ;M574 X1 Y2 S1 ; X home to max. Y home to max. Normally Closed limit switches.
                    ;M574 Z1 S2 ; Define Z to use Probe. Home to Min
                    M574 Z1 S2                                         ; Set endstops controlled by probe
                    M558 P9 H2 F500 T6000                             ; Set Z probe type to switch and the dive height + speeds
                    G31 P1000 X0 Y-30 Z0.62                              ; Set Z probe trigger value, offset and trigger height
                    M557 X5:285 Y5:235 S56:76                            ; Define mesh grid
                    M376 H15                                           ; Set bed compensation to taper off over 15mm
                    M305 P0 T100000 B4138 R4700                        ; Set thermistor + ADC parameters for heater 0
                    M143 H0 S120                                       ; Set temperature limit for heater 0 to 120C
                    M305 P1 T100000 B4138 R4700                        ; Set thermistor + ADC parameters for heater 1
                    M143 H1 S280                                       ; Set temperature limit for heater 1 to 280C
                    ; BLTouch - Heaters
                    M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel
                    M106 P0 S0 I0 F500 H-1                 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S1 I0 F500 H1 T45                ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 S"e3D_V6_0.4" D0 H1                         ; Define tool 0
                    G10 P0 X0 Y0 Z0                                   ; Set tool 0 axis offsets
                    G10 P0 R60 S220                                       ; Set initial tool 0 active and standby temperatures to 0C
                    ; Automatic power saving
                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                    M572 D0 S0.54                                   ; Pressure advance
                    ;use volumetric
                    M200 D1.75
                    ; 9 - RETRACTION SETTINGS
                    M207 S2.3 R-0.000 F4000 T3000 Z0.0
                    ;M207 ; echo the settings to the console to show they are applied
                    	; M207: Set retract length
                    	; Parameters
                    	; 	Snnn positive length to retract, in mm
                    	; 	Rnnn positive or negative additional length to un-retract, in mm, default zero
                    	; 	Fnnn retraction feedrate, in mm/min
                    	; 	Tnnn feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)
                    	; 	Znnn additional zlift/hop
                    	; Example: M207 S4.0 F2400 Z0.075
                    	; known to work M207 S2.3 R-0.000 F4000 T3000 Z0.0
                    ; FEEDRATE CONVERSIONS
                    	; 20mm/s = F1200
                    	; 35mm/s = F2100
                    	; 50mm/s = F3000
                    	; 70mm/s = F4200
                    	; 100mm/s = F6000
                    	; 120mm/s = F7200
                    	; 133mm/s = F8000
                    • A Former User?
                      A Former User
                      To me it seems like the communication with the ESP is working, but the resetting and entering bootloader fails.
                      If the board is past its warranty period or the problem is not considered for a warranty replacement i suppose you could try to use an FTDI adapter + esptool to re-flash the ESP if the provided binary is the same format esptool expects; or just poke around the Reset, GPIO00 and GPIO02 pins of the ESP to get it into the correct bootmode before letting RRF do the update. (but spidy sense says something got bust, or some peripheral is interfering, however I can't see any shared functions on those signals)
                      • A Former User?
                        A Former User @A Former User
                        @bearer said in Failed to update DuetWifiServer:
                        maybe this will shed some light on what doesn't work, seems there is no debug output from wifi when using M997 S1 - however this should get something.
                        M111 P14 S1 ;to enable wifi debug
                        M552 S-1 ;to disable the wifi module
                        M552 S0 ;to disable networking
                        M552 S1 ;to enable networking
                          dc42 administrators @vucheria
                          @vucheria said in Failed to update DuetWifiServer:
                          We've seen this happen a few times. Unfortunately, the only 100% reliable fix we know of when this happens every time you try to update is to replace the WiFi module.
                          • A Former User?
                            @dc42 shouldn't we see
                            Wifi:  ets Jan  8 2013,rst cause:2, boot mode:(1,6)
                            after M997 S1? just as we see
                            WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
                            after M552 S1 with debugging enabled?
                            Even if RRF doesn't switch to 74880 baud to read the bootloader message I'd still think we got some output (but seems not even if the flashing works?)
                            • vucheriaundefined
                              vucheria
                              Thank you so much guys for your support;
                              The board is out of warranty, but since I have no problems regarding the prints I will use it/wait for repair until it fails;
                              Anyways duet boards are the best, never looked back since 2018 🙂
                              • vucheriaundefined
                                @bearer
                                I'm not that confident in re-flashing the ESP and don't want to damage the board.
                                Thanks
                                • A Former User?
                                  A Former User @vucheria
                                  @bearer
                                  Thanks
                                  No worries, my interest was as much as determining cause as to solve problem.
                                  The good news is that while you do need hot air tools, the wifi module isn't the worst part to replace on a duet if you later need to replace it.
                                  • faazundefined faaz referenced this topic
