    gauge of wire for mini height sensor
    IR Height Sensor
    • JTBrownundefined
      JTBrown
      Hi, Could someone give me advice on what gauge wire I should use for wiring up a mini height sensor please? Many thanks
      zaptaundefined 1 Reply Last reply Reply Quote 0
      • A Former User?
        A Former User
        this one? https://duet3d.dozuki.com/Wiki/IR_Probe
        Hardly uses any current, so pick something that will fit the crimp terminals; usaully 26-24 gauge; can probably use smaller if you double up the copper to make a good crimp.
        • zaptaundefined
          zapta @JTBrown
          @JTBrown, as bearer said, gauge doesn't matter that much due to the low current but if the wire needs to flex all the time (e.g. due to a moving head), you want wire that for the same gauge, has more thin cores (strings). This one for example has 60 cores and thus will be more flexible.
          https://www.amazon.com/gp/product/B07MJ967YV
          • JTBrownundefined
            JTBrown
            Thanks guys
