    Problems with drivers and PWM
    • pkirillundefined
      pkirill
      I feel like I’m having “cascading failures“... I recently got around to installing the Hemera I bought a couple months ago. Testing the extruder, all I get is a loud buzzing noise. Then if I wait a few minutes, I get another buzzing (slightly higher pitch) and then a warning that driver temp is getting high. I tried moving from driver 3 to driver 4- same results. I’ve replaced the cable, double checked pin out, reversed direction in config.g, and tested with a know good stepper - all with the same results.
      The other issue I noticed is that only PWM 1 is controllable. PWM 0 and 2 both read 24V but fans don’t turn and shutting them down with gcode has no effect.
      Looking for any ideas... thanks!
      Here’s a video of what’s going on: https://files.veanea.net/data/public/8630b6
      https://files.veanea.net/data/public/00b3fb
      pkirillundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        Some early hermera shipments had cracked gears and will jam. Disassemble and check.
        • pkirillundefined
          pkirill @pkirill
          Just wanted to follow up here... Regarding the extruder, it turned out that I was relying on wire colors to match up the connections. [insert face palm here]
          Using the "Connecting stepper motors" section from this page gave me the answer and I feel pretty dumb for not referencing it sooner. https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
