    M563 when setting up toolboard.
    • jmjcokeundefined
      jmjcoke
      I have these changes in my config.g for adding 2 toolboards. The address for the boards are 20 and 21
      M569 P20.0 S1                                      ; physical drive 20.0 goes forwards
      M569 P21.0 S1                                      ; physical drive 21.0 goes forwards
      M584 X0:5 Y1 Z2 E0.3:0.4:20.0:21.0                     ; Mapping drive 0 and 5 to X and E3 to 20.0 and E4 to 21.0
      When you create tool assignments with M563 would this be correct?
      M563 P0 D20.0 H1 F0
      M563 P1 D21.0 H2 F0
      Thanks,
      Josh
      Joshua Coke
      Trick Laser Metal Max with Smart Effector
      Duet Wifi
      Zesty Nimble
      Mosaic Pallette+
      At work
      Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
        No. Use M584 to define the extruder driver numbers as you have done, then in M563 use the extruder numbers (0, 1, 2, 3) as normal.
        • jmjcokeundefined
          jmjcoke
          Thank You.
          Joshua Coke
          Duet Wifi
          Zesty Nimble
          Mosaic Pallette+
          At work
