    Duet 3 and g-code procedures and slicing
    Example setups and prints
    1.6k
    • monsterundefined
      monster
      I believe that I'm approaching that point where I could do a test print with my old "BFB Touch 3D" printer upgraded by Duet 3 Mainboard 6HC board & Pi.
      And I beginning to understand that there are basic things that aren't clear. And that is why I have these question.
      1. I do have homing process working now. But I absolutely have no idea at what point homing procedure will be happening. It doesn't happen when I switch printer on... Will it happen before each print?
        1.1) Does homing happen more then once per print? Is there a chance it will be happening during print somehow?
      2. After homing and before printing there should be some processes going, isn't it? Like extruding some filament for a bit for instance. What g-codes do that?
        2.1) Actually when filament extruded I'd like to run head(s) above some nozzle cleaning fence. What code supposed to do that? How do I config this whole process?
        2.2) Or is it "home" place where all this things should happen? (I hope not)
      3. Suppose I've done last bits of setup. How exactly do I slice before printing? I mean when using other printers (particularly BFB before upgrade) I had to slice model for some kind of flavor of g-code. Now that it is controlled by Duet 3 what should I know slicing related?
      Thank you in advance.
      • A Former User?
        A Former User @monster
        1. up to you, you can put g28 in your config.g file, or you can put it in the start.g file or you can leave it out (the latter will require you to manually home before printing)
        2. either start.g or your slicer
        but i'm sure someone will elaborate a little on that
          The world is your oyster. You are free to script it out any way you wish.
          The axis must be homed before printing obviously. Homing is done with G28. Typically this would be placed in the slicer's start gcode section so that it gets prepended to the start of the gcode file that gets sent to the printer.
          Alternatively, you can use start.g in the /sys/ folder. This macro gets called by the firmware at the start of every print. You can use it to home the printer, preheat the heaters, etc.
          Homing isn't normally done during a print, though it would need to happen if trying to recover a print after a power loss.
          Doing a prime line will require you to manually craft some gcode commands to do the following in some way:
          • heat the hot end
          • place the nozzle where you want to prime
          • extrude a line of filament over an area
          • etc etc
          What slicer are you using? If you are coming from a proprietary slicer you may want to look into migrating to PrusaSlicer and/or Cura. Each will have it's own learning curve.
          monsterundefined 1 Reply Last reply Reply Quote 0
          • monsterundefined
            monster @Phaedrux
            @Phaedrux said in Duet 3 and g-code procedures and slicing:
            Problem is that I don't know what to wish 😄 Or should wish 🙂
            That is why I kinda hope that someone shares "best practices" or just some good hints 🙂
            Got it!
            Can it really recover print after power loss? Wow!
            At least my current homing process will for sure hit heads into half printed build. Thinking more of it. Homing Z is more like doomed to crash into something that is on bed as Z end switch is stops homing once bed is close to heads.
            • heat the hot end
            • etc etc
            Sorry for not being familiar with terms. I guessed "prime line" means pre-extruding some filament before the print (to get extruder going)?
            If yes then - got it 🙂
            That is something that should be sitting in start.g, right?
            I'm familiar with Cura - used it several times when printed on Multimaker.
            The printer I'm working on now used some own weird/crazy/ugly software which I'd don't wanna see again 😄 That is why (mostly) I started the upgrade it first place.
            So if I could use Cura - I'd be happy to.
            But again, I believe that Cura has a setting for what kind of hardware it making g code for. And that is the question I was asking basically - how to configure slicer to make code suitable for my printer?
            In the printer I'm working on there are 3 extruders and of course slicer must have an option to slice taking that into account, right?
            I might be saying complete nonsense, sorry if so 🙂 but I guess Cura printer selection for the reason of building suitable for that hardware g-code, isn't it? That makes me wonder what should be my settings in it...
            I've actually just now loaded up Cura and there is "Add printer"
            I noticed that it doesn't see my network printer 😞 even though that on same computer it does access it WebUI.
              Phaedrux Moderator @monster
              @monster said in Duet 3 and g-code procedures and slicing:
              I noticed that it doesn't see my network printer even though that on same computer it does access it WebUI.
              Only Ultimaker printers will show up on the network. You will need to create a custom printer entry using your parameters.
              There is a plugin for Cura that allows sending the sliced gcode directly to the duet.
              Cura does support multiple extruders/tools.
              • monsterundefined
                monster @Phaedrux
                Ahaa! Got it! Thank you.
                Dam... that million of settings in Cura 😂
                • Danalundefined
                  Danal
                  Both Cura and SlicerPE have plugins to send g-code directly to a Duet.
                  In terms of telling the Slicer "which printer", you will find that nobody has built-in profiles for "Duet" because just saying "Duet" that doesn't specify the geometry of the printer.
                  It takes under five minutes in either slicer to define a custom printer, and key in the dimensions. I have customs in SlicerPE for my big delta (605mm diameter 620 z) and for a "Jubilee" style multi-tool printer, (about 305x305x300) including all the tools. Each took only moments to setup.
                  • monsterundefined
                    monster
                    I've been practicing with Cura.
                    I still can't get print/simulate directly from Cura. There I added 3 printers 🙂
                    One with http://printer.local address and some name != printer name in WebUI
                    Another with http://<ip_address> and some name != printer name in WebUI
                    and another with http://<ip_address> and some name == printer name in WebUI
                    attempt to print/simulate on either gives: There was a network error: 203 Error transferring ....
                    But I could upload it via WebUI and tried to print without filament - seems heads are moving right way 😄
                    resamundefined 1 Reply Last reply Reply Quote 0
                    • A Former User?
                      A Former User
                      I usually slice with simplify3d and for my start up I have the following in my start script in simplify3d which as you can see carries out numerous functions, this have been working well for a while now.
                      M290 S0.0 ; clear any baby stepping
                      G28 ; home all axes
                      G1 X20 Y50 ; move nozzle to start point
                      G92 E0 ; zero extruder
                      G1 Z0.5 ; lower nozzle
                      G1 Y250 E30 F1200 ; slow wipe
                      G1 Z2 ; lift nozzle
                      G29 S1 ; load height map
                        Here's my start sequence for reference.
                        start.g
                        M106 P2 F30000 S0.5 H-1 C"Duet Fans"
                        M140 S65		; set heated bed to 65 and release
                        T0			; Select Tool 0
                        M291 P"Print Started. Preheating and Homing." T10
                        G4 S1
                        M98 P"0:/macros/Musical Tunes/LuckyTune.g" ; Lucky tune to start print off on the right foot
                        G4 S1
                        M220 S100		; Set speed factor back to 100% in case it was changed
                        M221 S100		; Set extrusion factor back to 100% in case it was changed
                        M290 R0 S0		; clear babystepping
                        M106 S0			; Turn part cooling blower off if it is on
                        G10 P0 R0 S80		; Set extruder to 80 and release
                        M190 S65		; set heated bed to 65 and wait
                        G28			; home XYZ
                        G29 S1			; load heightmap
                        M400
                        G10 P0 R80 S180	; Set extruder to 180 and release
                        M98 P"0:/sys/ZSpeedsPrint.g"	; Load Z speeds for printing
                        M98 P"0:/sys/CurrentsPrint.g"	; Load print motor currents
                        ; Slicer Start Gcode begins.
                        ZSpeedsPrint.g
                        ; 0:/sys/ZSpeedsPrint.g
                        ; Used to set faster z speeds for printing.
                        M566 Z120			; Set maximum instantaneous speed changes (mm/min) (Jerk)
                        M203 Z600		; Set maximum speeds (mm/min)
                        M201 Z240 		; Set maximum accelerations (mm/s^2)
                        CurrentsPrint.g
                        ; 0:/sys/CurrentsPrint.g
                        ; Used to set normal motor current
                        ; Make sure these values match those in config.g
                        M913 X80 Y80 Z80 E80					; set X Y Z E motors to 80% of their max current
                        Slicer start gcode
                        M98 P"0:/sys/PrimeNozzle.g"
                        M98 P"0:/sys/StartGCode.g"
                        Primenozzle.g
                        ;M98 P"0:/sys/PrimeNozzle.g"
                        G90 			; Absolute positioning
                        G1 X1 Y270 F6000 	; Move to front left corner
                        M400 			; clear movement buffer
                        M116 			; Wait for temps
                        G1 Z0.3 F100		; Move Z to prime height
                        G91 			; Relative positioning
                        M83 			; Relative extrusion
                        G1 X40 E10 F300 	; Prime nozzle
                        G10			; Retract
                        G1 Y-1 X1 F10000 	; Wipe nozzle
                        M400
                        StartGcode.g
                        M291 P"Good luck and Godspeed." T5 ; Good luck and Godspeed.
                        ; Battle Cry!
                        M400
                        G4 S1
                        M300 P200 S523.25
                        G4 P200
                        M300 P200 S659.25
                        G4 P200
                        M300 P200 S739.99
                        G4 P250
                        M300 P285 S880.00
                        G4 P450
                        M300 P285 S880.00
                        G4 P285
                        M300 P625 S1108.73
                        G4 S1
                        M400
                        ; Start the print
                        Slicer End Gcode
                        M0 ; calls stop.g
                        Stop.g
                        ; stop.g
                        ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                        ; Also called by slicer end gcode by M0
                        M400			; Finish move queue
                        M104 S0 		; Extruder heater off
                        M140 S0 		; Bed heater off
                        M106 S255 		; Fan at 100 to cool nozzle and bed
                        G1 E-2 F9000			; Retract filament 2mm
                        G1 X5 Y5 F9000		; Wipe nozzle
                        G1 Z20 F500			; raise nozzle 5mm from printed part
                        G90				; absolute positioning
                        G1 X150 Y130 F6000		; Move x and Y axis over to bed center so probe is on top of bed
                        ;M104 S35		; Set hot end low and wait
                        G4 S60			; Wait 5 minutes
                        ;M116			; wait for temp to drop
                        G28 X Y			; Home X and Y
                        G28 X Y			; Home it again, Sam.
                        M84			; Steppers off
                        M98 P"ZSpeedsNormal.g"	; Load normal z speed settings again.
                        M106 S0			; Fan off
                        M106 P2 F30000 L0.1 X0.8 B0.5 T35:70 H100:101:102 C"Duet Fans"
                        ;Play a little beep beep beep to show print ended.
                        M400			; Clear queue again before jingle
                        G4 S1
                        M300 P250 S750
                        G4 P251
                        M300 P200 S1250
                        G4 P201
                        M300 P250 S750
                        G4 P251
                        M300 P200 S1250
                        G4 P201
                        M300 P250 S2500
                        G4 P251
                        M300 P150 S2000
                        G4 P151
                        M300 P150 S2500
                        G4 P151
                        M300 P350 S3700
                        G4 P351
                        Doing things this way has a few benefits. Mainly that the slicer start gcode is basically nothing. That way I only have to change the files on the Duet and regardless of which slicer I use the starting and ending behaviour is the same. It also allows me to do a preheat and nozzle prime and still allows the slicer to control the print temps.
                        • monsterundefined
                          monster @Phaedrux
                          @Phaedrux Thanks for sharing - that sets the bar... 👨‍🏫
                          LOL 😁
                            LuckyTune.g
                            Sorry, I forgot that one.
                            ; 0:/macros/Tunes/LuckyTune.g
                            M400 ; Empty the movement buffer
                            M300 P200 S1000
                            G4 P210
                            M300 P200 S1250
                            G4 P210
                            M300 P200 S1100
                            G4 P201
                            M300 P200 S2000
                            G4 P201
                            M300 P200 S1500
                            G4 P201
                            M300 P200 S1000
                            G4 P201
                            M300 P200 S1300
                            G4 P201
                            M300 P200 S1000
                            G4 P201
                            M300 P300 S1500
                            • monsterundefined
                              monster
                              @Phaedrux why do you use M400 often? I actually don't get why emptying of the buffer needed as command cause I though while one movement command is being executed then next command in script will not start. Which in turn means when next command is being executed all the movement of previous one is done. Or do I get some concept wrong? Perhaps movement buffer is not something I picture myself...
                              • monsterundefined
                                monster
                                Slicer start gcode
                                Another piece of setup I do not understand fully.
                                what is "Slicer start gcode"? (as well as "Slicer End Gcode")
                                Is it some script that defined in slicer software to be included in each g-code to print?
                                And then "0:/sys/PrimeNozzle.g" & "0:/sys/StartGCode.g" seems located in your printers files system, right? That means your slicer software is counting on presence of those files in printer, correct?
                                Or is "Slicer start gcode" an another script in printer that being called right before sliced model to be printed?
                                There are so many unknown things here I must admit. For example is there a list of standard scripts like start.g stop.g homex.g etc... that getting called in some occasions?
                                monsterundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                • monsterundefined
                                  monster @monster
                                  Slicer start gcode
                                  Got it! It is in printer settings in Cura! 😉
                                    Probably unnecessary for the most part, done mostly out of habit during troubleshooting. Basically M400 just says wait until the movement queue is complete up to this point before executing what comes after.
                                    For the music bits I found M400 before helped it play the tones more consistently without stutters, but I haven't tested that in quite some time.
                                      Yes that's right. Most slicers have a section of text boxes that allow you to enter custom gcode commands that will get inserted at certain locations, such as before the print starts, when the print is finished, at layer changes, at tool changes, etc.
                                      Example from PrusaSlicer:
                                      That's right. M98 allows you to call a macro found on the Duet SD card, either in the macros or sys folder.
                                      Yes, there is.
                                      https://duet3d.dozuki.com/Wiki/Setting_up_macro_files_for_common_tasks
                                      https://duet3d.dozuki.com/Wiki/Macros
                                      • resamundefined
                                        resam @monster
                                        Apparently Duet3 with SBC does not provide the same API as RepRapFirmware 2 and previous. This means all the slicer integrations are broken - I know of at least PrusaSlicer, and the Cura plugin (I am the maintainer if it).
                                        Looks like once it is RRF that broke compatibility with slicers - usually it is slicers who break magic comments and other things 😜
                                        @dc42 @chrishamm any thoughts on this topic? It would be really nice if the well-known RRF HTTP API with rr_connect etc. would also be supported on Duet3+SBC!
                                        It's not only slicers, also lots of other scripts, timelapse tools, and other integrations were relying on this API.
                                        • monsterundefined
                                          monster @Phaedrux
                                          Yes, there is.
                                          Priceless! 👍
                                          • monsterundefined
                                            monster
                                            I can't remember where did I read that by now.
                                            But back then when I was choosing controller I did read somewhere that when Duet 3 used with Pi it (or I guess Pi) can do slicing. And if my memory not mistaking that was saying about actually Cura slicer in Pi.
                                            Is it something I could try? I mean try to use that slicer.
                                            Hope it is not to difficult to setup and use. May be that could solve my problem...
