    TRONXY X5ST-500 - covid19
    • FABIO_F
      FABIO_F last edited by FABIO_F
      I have an X5ST-500 printer where I used the frame and some parts to use with DUET2 Ethernet + Duex 5 + Titan Aero.
      I am days trying to operationalize these printers to make protection masks against the virus and I am not getting it.
      My configuration is COREXY, but when I try to start printing it shows an unevenness in one of the Z axes and automatically triggers the emergency stop.
      In addition now it started to present some errors like:
      Warning: motor phase A may be disconnected reported by driver (s) 4
      Warning: motor phase B may be disconnected reported by driver (s) 4
      If anyone can help thank you, here are my settings
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 29 2020 21:13:18 GMT-0300 (-03)
      G29 ; probe the bed and enable compensation
      ; bed.g file for RepRapFirmware, generated by Escher3D calculator
      ; 10 points, 6 factors, probing radius: 150, probe offset (-20, -12)
      G30 P0 X0.00 Y150.00 Z-99999 H0
      G30 P1 X129.90 Y75.00 Z-99999 H0
      G30 P2 X129.90 Y-75.00 Z-99999 H0
      G30 P3 X0.00 Y-137.84 Z-99999 H0
      G30 P4 X-112.42 Y-64.91 Z-99999 H0
      G30 P5 X-119.83 Y69.19 Z-99999 H0
      G30 P6 X0.00 Y75.00 Z-99999 H0
      G30 P7 X64.95 Y-37.50 Z-99999 H0
      G30 P8 X-49.55 Y-28.61 Z-99999 H0
      G30 P9 X0 Y0 Z-99999 S6
      G28 ; home
      M401 ; deploy Z probe (omit if using bltouch)
      G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M402 ; retract probe (omit if using bltouch)
      config.g
      M550 P"My Printer" ; set printer name
      G21 ; Work in millimetres
      ;M667 S1 ; Select coreXY , rev 2.02 and earlier
      M669 K1 ; Select CoreXY mode
      M555 P2 ; Set output to look like marlin
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M569 P0 S1 ; physical drive 0 goes forwards Drive 0 runs forwards, active low enable, (X)
      M569 P1 S1 ; physical drive 1 goes forwards Drive 1 runs forwards, active low enable, (Y)
      M569 P2 S1 ; physical drive 2 goes forwards Drive 2 runs backwards, active low enable, (Z1)
      M569 P4 S1 ; physical drive 4 goes forwards
      ;M584 X0 Y1 Z2 E3:4 ; set drive mapping FFR alterado
      M584 X0 Y1 Z2:4 E3; dois motores Z conectados às saídas Z e E1 do driver FFR alterado
      M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis FFR Alterado
      M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200 FFr Alterado
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z4000.00 E837.00:837.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-20 Y-12 Z0 S1 ; set axis minima
      M208 X455 Y420 Z380 S0 ; set axis maxima
      M574 X1 Y1 S0 ; set active high endstops
      M581 Z1 S0 T0 C0 ;Set Z1 endstop as an e-stop for Z protection if Z probe fails when probing the bed.
      ;M558 P2 H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z10.0 ; set Z probe trigger value, offset and trigger height
      M557 X20:450 Y30:420 S100 ; define mesh grid. (S) = Espaçamento entre os pontos
      ; G31 P500 X-30 Y-5 Z2.0 // ALTERADO FFR
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M564 H0
      M42 P2 S255 ; Turn led lighting on full
      M98 PLevelLeadscrews.g ; Option to perform leadscrew levelling
      M98 PEnable Mesh Levelling ; Option to enable on start up
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      ;G30 ; home Z by probing the bed
      ;G1 H2 Z5 F6000 ; lift Z relative to current position
      G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      ; homex.g
      ; called to home the X axis
      G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000 ; go back a few mm
      G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000 ; lower Z again
      G90 ; absolute positioning
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000 ; go back a few mm
      G1 H1 Y-215 F360 ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      G1 X15 Y15 F6000 ; go to first probe point
      ;G91 ; relative positioning
      G1 Z10 F10 ; lift Z relative to current position
        Phaedrux Moderator @FABIO_F last edited by
        @FABIO_F said in TRONXY X5ST-500 - covid19:
        It sounds like one of your Z motors isn't wired correctly. You can verify the motor phases with this: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
