    Solved Door Switch
    • FoxLab
      FoxLab last edited by
      I'm using a Duet 2 Maestro with firmware 3.01-RC4 running.
      Is there any slick possibility to implement a door switch which sends the print straight into pause mode/position?
      I was initially thinking about to use a filament monitor using M591 command. But I failed.
      I implemented the the code into config.g "general prefrences" as follows
      M591 D3 P1 ; Door Switch (D3 = Driver 3 for E0 Motor/ P=High signal when door closed)
      I'd be happy to receive a comment on other solutions.
      The potential alternative solution using M581 and M582 on a maestro did not become cleare to me until yet.
      Thank you and Happy Easter
      Dominik
      • timothyz
        timothyz last edited by
        https://duet3d.dozuki.com/Wiki/Using_M581_-_External_Triggers_and_Building_a_Control_Panel
        Then you could point that to a gcode file with M25 in it.
        • FoxLab
          Hi Timothyze,
          thank you for your prompt reply and please excuse my slow feedback.
          For those who are interested:
          I could solve my Door Switch issue using the suggested M581 command and the extruder Extruder Endstop of E0 ("e0stop"). I have used it in a manner of triggering a "software" based emergency stop (https://duet3d.dozuki.com/Wiki/Connecting_an_Emergency_Stop)
          M25 was not necessarry as M581 command now allows to directly trigger the pause print g-code by setting the T parameter to 1 (guess this only works since RepRapFirmware 3.01RC2 and later).
          I'm using a optical endstop which hase a high edge when the door is closed.
          Here is the code which I used and embedded into config.g => General preferences:
          M950 J1 C"e0stop" ; Jnn = Input pin number (RRF 3.01RC2 and later only)/ C"name" Pin name(s) and optional inversion status.
          M581 P1 T1 S0 C1 ; P1 = specifies input trigger (corresponds to M950 J1)/T1 = pause print/S0 = falling edge signal when door is opened/C1 only trigger when printing
          Best regards
          Dominik
