    What would cause the console to not report data?
    Firmware installation
    • Nuramori
      Nuramori last edited by
      I had updated my duet3 + SBC to 3.01rc6 and when I do any command that should report back info, it doesn’t show up in the webpage. I repeatedly sent a G30 S-1 which should send back the z height it proved at, but it only shows a green bar with the command as executed but not the result. I get this with a number of commands. M122 and M115 still works to return data.
      gtj0 1 Reply Last reply Reply Quote 0
        Have you also updated your DSF to the latest unstable? 1.3.1 I think?
        Nuramori 1 Reply Last reply Reply Quote 0
        • gtj0
          gtj0 @Nuramori last edited by
          @Nuramori There are known issues...
          https://forum.duet3d.com/topic/15343/dsf-1-3-1-unstable-released
          • Nuramori
            Nuramori @Phaedrux last edited by
            @Phaedrux I did. I'm on the unstable branch, and I confirmed that I am on 1.3.1.
            I'm not sure if it's related, but the system has emergency stopped more frequently than not ever since I moved to RC5 then RC6. I can't find a common thread to the issue of the random halt. At first I thought maybe the Pi was overheating, but I have a cooler, and as soon as it happened the last time, I checked and the temp was 38c. The temp of the cuet3 was 34c (I actively cool it.)
            once I reboot everything, it will work fine, though if I reboot too soon, the Z axis refuses to home, or even move. Another reboot will free up the z axis.
            The time before it halts has no time or layer correlation to anything I can find.
            • gtj0
              gtj0 last edited by
              DSF 1.3.1 is required for RRF 3.01-RC6 but IMHO 1.3.1 is not stable enough for anything other than testing 1.3.1.
              • gtj0
                gtj0 last edited by
                Actually, you'd be better off disconnecting the Duet3 from the Pi and running the Duet3 in standalone mode.
                • Nuramori
                  I understand. I'm ok with helping provide feedback. I am conflating two issues, but the initial one is strange, where a command like G30 S-1 won't return the value I need to set the z probe. I ended up just looking at the dashboard to see the z value in the one part of the screen.
                  The other issue of random halting began with using RC5, so that was before RC6 and before using 1.3.1. That one is a bit more problematic.
