    Run G1 for 2 tools simultaneously?
    79
    • CJ.BRAVO
      CJ.BRAVO last edited by
      Hey,
      As I understand gcode, it has to wait for the line of command to finish.
      if I run this segment:
      T0
      G1 X24.577 Y197.646 E0.5019 F1470
      G1 X26.626 Y197.646 E2.7959
      it has to finish line 1 before line 2, right?
      But can I do this:
      T0
      T2
      G1 U26.626 Y197.646 E2.7959
      And have T2 line run at the same time? T2 is set to be on a different X axis (U) but both are running on the same Y axis.
      Why would I do this?
      I'd like to try and print parts of the same model using two tools at the same time.
      Using DUET 3
      Thoughts?
      • droftarts
        droftarts administrators @CJ.BRAVO last edited by
        @CJ-BRAVO I think youโ€™re describing an IDEX printer. You can set up a tool so it prints on both extruders at the same time. See : https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian#Section_Creating_a_tool_that_uses_more_than_one_carriage_to_print_multiple_copies_of_an_object
        CJ.BRAVO 1 Reply Last reply Reply Quote 0
        • bot
          bot last edited by
          You could also simply command the U axis in the first line
          G1 X123.4 Y123.4 U143.2 F9000000000000000000000000000000 E0.00000001
          ๐Ÿ™‚
          *not actually a robot
          • CJ.BRAVO
            CJ.BRAVO @bot last edited by
            @bot
            yeah but lets say I'd want a different E amount...
            bot 1 Reply Last reply Reply Quote 0
            • bot
              bot @CJ.BRAVO last edited by
              @CJ-BRAVO
              Oh, right, yeah, no.
              • bot
                bot last edited by
                Maybe you can specify two E moves?
                G1 X10.0 Y12.0 U15.0 E0.5:0.4
                • CJ.BRAVO
                  CJ.BRAVO @droftarts last edited by
                  @droftarts
                  I know IDEX but the link you mentioned is for 2 copies of the same model.
                  I'm thinking of a simple model that would run the same Y but different X,U and E's.
                  • CJ.BRAVO
                    @bot
                    Not sure if that works in that case.
                    There's M567 for mixing ratio but that's per specific tool...
                    • bot
                      @CJ-BRAVO only one way to find out ๐Ÿ˜‰
