    Unsolved Duet reporting inaccurate percentage.
    Duet Web Control
    682
    • Turbo
      Turbo last edited by
      Dont know why this just started happening, but my file finishes at 80% and then jumps straight to 100%. The layer count is correct, and i have an E in the comments of each line in my end gcode in Prusaslicer. Dont know what else it could be.
      This is my end gcode
      M104 S0 ; E turn off temperature
      M140 S0 ; E turn off heatbed
      M107 ; E turn off fan
      G91 ; E relative position
      G0 Z+5.0 F3600 ; E
      G90 ; E back to abosolute position
      {if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+40, max_print_height)}{endif}  ; E Move print head up
      G0 X100 Y200 F3000 ; E
      M84 ; E disable motors
      Cant stop tuning wont stop tuning.
      Dbot, Custom i3, Voron 0&2
        Phaedrux Moderator @Turbo last edited by
        @Turbo said in Duet reporting inaccurate percentage.:
        What does this evaluate to in the sliced file?
        Did this also start happening after tuning pressure advance as per your other thread?
        Turbo 1 Reply Last reply Reply Quote 0
        • Turbo
          Turbo @Phaedrux last edited by
          @Phaedrux If the final z height is under a defined value, itll raise 40mm to get out of the way, so long as it doesnt hit the max height. this didnt happen after tuning pa.
            Firmware and DWC versions?
            Which percentage complete were you looking at?
            Also, I meant what does that conditional line look like in the final gcode file?
            • Turbo
              Turbo @Phaedrux last edited by Turbo
              @Phaedrux
              DWC: 2.0.7
              Board: Duet WiFi 1.02 or later
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
              Duet WiFi Server Version: 1.23
              Hits 82% or so every time, then jumps to completed.
              I went back to stock prusa end gcode to see if it would resolve which looks like:
              G4 ; wait
              M221 S100
              M104 S0 ; turn off temperature
              M140 S0 ; turn off heatbed
              M107 ; turn off fan
              {if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; E Move print head up
              G1 X0 Y200 F3000 ; E home X axis
              M84 ; disable motors
              This is what the processed code looks like for that end.gcode. I dont see any issues, but im not an expert.
              ;END gcode for filament
              G4 ; wait
              M221 S100
              M107 ; turn off fan
              G1 Z31.95 ; E Move print head up
              I cant seem to find anything abnormal in the gcode, but here it is. maybe you'll find something
              V4_EarSavers_CCPrinter_5.gcode
              • Turbo
                Im going to try copying the end gcode from my other printer (only changing one z value since its not as big), since that one reads percentage properly, and see if the issue persists.
                • Turbo
                  @Phaedrux
                  Print finished with the new gcode. Its not the end script causing it. it still ends at 82%, despite being the same end gcode on my other printer, which displays the percentage properly.
                  What else could it be
                  • Turbo
                    tried another print with no end .gcode. I'm still having this issue.
                    • Turbo
                      Is it possible the start gcode would cause this issue? Ive ran the same gcode (essentially, changing retraction/PA) on two printers and one correctly reads the percentage, while one finishes around the 82% mark, not the same value each time. 81.2, 82.6, and 82% is what ive witnessed.
                        I can't see anything obvious in the gcode file.
                        • Turbo
                          Bumping this topic because the issue remains unresolved. A print just finished at 55.8%
                            Are you referring to the % complete reported by DWC, or by PanelDue?
                            Those % complete figures are not based on object height, which is why your end GCode does not affect them. AFAIR the % complete figure is based on filament consumption vs. filament required (if the filament length required is available in the GCode file), otherwise on the percentage of the GCode file that has been processed.
                            Your sample GCode file has these figures:
                            ; filament used [mm] = 6904.1
                            ; filament used [cm3] = 16.6
                            ; total filament used [g] = 0.0
                            ; total filament cost = 0.0
                            The 6904.1mm figure is being picked up by RRF. Next time you print this file (or another file that shows the same issue), please monitor the Filament Usage value of the DWC status page towards the end of the print, to see whether it is converging towards the filament usage recorded in the GCode file, or towards a lower value.
                            I note that your GCode file contains some negative extrusion amounts:
                            G1 F8640.000
                            G1 X18.241 Y12.662 E-0.33092
                            G1 X19.422 Y11.978 E-0.31506
                            G1 X20.660 Y11.628 E-0.29710
                            G1 X21.913 Y11.463 E-0.29192
                            G1 E-0.06500 F2100.00000
                            I presume this means you have "wipe while retracting" or similar enabled in the slicer.
                              I've just run that file in simulation mode. It finished just after reporting 88% complete with >1m of filament remaining. This suggests to me that either RRF is accumulating filament usage incorrectly, or that PrusaSlicer is reporting incorrect filament usage for the particular options you are using.
                              I think that RRF may be being confused by wipe during retraction. Please can you try running that print in simulation mode and check that you get the same results as me (or run another file if you prefer, and note the % complete figure it reaches just before the end). Then slice that file again, turning off wipe-while-retract. Simulate that file and see if the behaviour is different.
                              Turbo 1 Reply Last reply Reply Quote 1
                              • Turbo
                                Turbo @dc42 last edited by Turbo
                                @dc42 running that .gcode I linked earlier shows a correct readout in simulation mode; reaching 100% as expected. I am referring to the DWC %
                                EDIT: i ran the file that finished at 55% from earlier in simulation mode, and it showed proper percentage up to 100%
                                  dc42 administrators @Turbo last edited by dc42
                                  Strange, when I ran your file in simulation mode (using RRF 3.01-RC7) it definitely jumped from about 88% to 100%.
                                  I am fairly sure that wipe-while-retract is confusing the filament used accumulator, but I don't know if that is the only issue here. Can you re-slice one of your prints with wipe-while-retract disabled and see if the problem goes away?
                                    This is now fixed in the 3.01 source code and in the firmware binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                                    • Turbo
                                      @dc42 disabling wipe while retract solved it! Although am i able to use 3.01 with a duet 2 wifi board?
                                        Yes you can, however you will need to make substantial changes to your config.g file if you do upgrade. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files for the details.
                                        The fix will probably make it to RRF 2 eventually, but not until it has been in RRF3 long enough for me to be certain that it has no unexpected side effects.
                                        Turbo 2 Replies Last reply Reply Quote 0
                                        • Turbo
                                          @dc42 Got it, thanks. I always assumed the RRF 3 would only work for Duet 3 boards and later. IDK Why
                                          • Turbo
                                            @dc42 After updating to RRF3.0 RC7, the issue is still present it seems. i have a current print about 50% done, however, the DWC only shows 6%, and i can watch it go up and down in percentage, which i dont think is supposed to happen. The object is consistent all the wey to the top, so there shouldnt be any large discrepancies that would affect %. This is with wipe while retract is on, because it does affect my print quality noticeably.
                                              Yes the bug is present in the 3.01-RC7 release, but fixed in the post RC7 build that I linked to earlier.
                                              • SpoonUnit
                                                SpoonUnit last edited by
                                                I'm not sure if this issue is connected with my recent move to RRF3.3b2. Since I did, I've had a number of prints telling me they are over 100% complete. Querying the forum I found this thread, and the detail that completion calculation is based on GCODE-embedded filament usage.
                                                In the GCODE file I see:
                                                ; filament used [mm] = 13125.43
                                                In DWC, I see this at the end of the print during my cool down phase:
                                                and
                                                The layer count is off, but the filament consumption seems to suggest the reported job completion level should be 99%, not 144.7%.
                                                To add to the mix, I'm also testing ArcWelder, so the GCODE has G2/G3 commands scattered throughout.
                                                dc42 chrishamm 2 Replies Last reply Reply Quote 0
                                                  dc42 administrators @SpoonUnit last edited by
                                                  One for @chrishamm.
                                                  • chrishamm
                                                    chrishamm administrators @SpoonUnit last edited by
                                                    @spoonunit Please share the full G-code file and I'll have a look.
                                                    Duet software engineer
                                                    SpoonUnit 1 Reply Last reply Reply Quote 0
                                                    • SpoonUnit
                                                      SpoonUnit @chrishamm last edited by
                                                      @chrishamm here you go
                                                      seq26.gcode
                                                      SpoonUnit dc42 2 Replies Last reply Reply Quote 1
