    Measuring the Duet's time-left estimations
    246
    • zapta
      zapta last edited by
      While staying at home and printing parts for Covid masks I decided to use the time and measuring the time-left estimations provided by the Duet (RRF 2.04).
      This is the print I used to collect the data:
      First the reported percentage, this is the red line in this graph below and as you see its pretty close to the ideal (blue line). (X axis is print time in secs). I presume that this comes from embedded markers by the PrusaSlicer (?)
      Next are the reported time left by layer, filament and file respectively, compared to the correct value (blue line). These get wild in the first 1/3 of the print and get close enough in the second half of the print. The by-layer converges the last and the by-file gets very far at the beginning of the print.
      Next I computed an estimation based on print-time-so-far and percentage and got the graph below. It also has issue at first 25% of the print
      I do not know what other information the slicer passes in the gcode. For example, an estimation of the total print time, which the slicer computes anyway, would help stabilizing the estimation based on time and percentage.
      BTW, this is the python script I used to collect the data during the print. It's based on http/json code I copied from danal@'s library.
      #!/usr/bin/python
      # Tracks Duet3d print time predictions and prints the data in CSV format.
      # Tested with Python 2.7.16.
      # Hit Ctrl-C to stop.
      import json
      import time
      import urllib
      url='http://10.0.0.9/rr_status?type=3'
      print 'Duet3 URL: [%s]' % url
      def ReportHeader():
        print ','.join([
          'status',
          'printer_time',
          'print_time',
          'layer',
          'fraction',
          'sec_left_layer',
          'sec_left_filament',
          'sec_left_file' ])
      def ReportCurrentValues():
        response = urllib.urlopen(url)
        doc = json.loads(response.read())
        #print json.dumps(doc, sort_keys=False, indent=2)
        values = [
          str(doc['status']),
          str(doc['time']),
          str(doc['printDuration']),
          str(doc['currentLayer']),
          str(doc['fractionPrinted']),
          str(doc['timesLeft']['layer']),
          str(doc['timesLeft']['filament']),
          str(doc['timesLeft']['file']),
        print ','.join(values)
      # Main
      ReportHeader()
      while True:
        time.sleep(60)
      • zapta
        ... The 'support remaining times' checkbox of my prusaslicer was off. Does the Duet make use of it? If so, I can repeat the measurement with the checkbox on.
        • Danal
          Danal last edited by
          I am fairly sure that checkbox adds an M73 commands to the G-code to cause messages to appear on the console (or LCD) of certain printers.
          Duet does not support this; nor do I believe it would help your tracker in any way.
          zapta 1 Reply Last reply Reply Quote 0
          • Danal
            And, oh by the way, very cool!
            Now, add python matplotlib and do it in real time on the screen 🙂
            • zapta
              zapta @Danal last edited by
              @Danal, when I enable that checkbox I see these minute markers with percentage and minutes left
              M73 P0 R445
              M73 P0 R445
              M73 P0 R444
              M73 P0 R443
              M73 P0 R442
              M73 P0 R441
              M73 P1 R440
              M73 P1 R439
              M73 P1 R438
              M73 P1 R437
              M73 P2 R436
              Let's say that I print it with duet, any idea how to monitor the P and R values of the last M73 marker? I can preprocess the gcode file if needed.
              My goal is to compare the prusaslicer percentages and time-left estimation to the actual values.
              Danal 1 Reply Last reply Reply Quote 0
              • zapta
                @Danal said in Measuring the Duet's time-left estimations:
                ... or ask the DWC developers to add it to the UI in some diagnostic tab. 😉
                • Danal
                  Danal @zapta last edited by
                  @zapta said in Measuring the Duet's time-left estimations:
                  M73 P0 R445
                  M73 P0 R445
                  M73 P0 R444
                  M73 P0 R443
                  M73 P0 R442
                  M73 P0 R441
                  M73 P1 R440
                  M73 P1 R439
                  M73 P1 R438
                  M73 P1 R437
                  M73 P2 R436
                  You could change them to M117 console messages. And then copy those from the console after the print, excel, etc, etc.
                  • zapta
                    @Danal, is there a way to poll in real time console messages via http?
                    • Danal
                      Unfortunately, the console on Duet RRF (or RRF+DSF) is not really managed for multiple web sessions to work with each other. If a given web interface "pulls" a console message, others will miss it. This may not be a 100% accurate description, but it is very close to the way it works.
                      If this happens to be a 3+Pi, you could scan the 'sudo journalctl -u duetwebserver' for these messages. Maybe.
                      • droftarts
                        droftarts administrators @zapta last edited by
                        @zapta Thanks for the analysis. Have you compared Duet 'simulation' times to print time, too? This should be the most accurate way of calculating time remaining. We have been discussing removing the time-left-by-layer and layer stats (because it doesn't really tell you much and is usually the most inaccurate estimation); dc42 has been keen to do this for a while. I've suggested that we should implement background simulation of all files, too. They could be recalculated automatically if settings are changed, too.
