code ???? o k then ???
as i navigate thru the different files i notice things that were changed. My inexperience with code makes me ask some of the simplest questions. hope you guys don't mind.... the changes im talking about has to do with obscure entries like mention of a bl touch in several files or the fact that the end stop settings were changes " my question would be" if i changed a setting in the g-code, does it change and add thing to other places and if it does when its changed back does it revert to the original setting or does one have to go thru the entire files to remove the things no longer needed such as config.g...... home all......yhome.... ect. besides the lack of coding knowledge, one need to understand the system an how it react to an individual entry or command thanks again
Can you give a specific example of what you mean? I'm not exactly sure what you're asking.
Generally though, if you send a gcode to configure something, either manually or in config.g, it will stay in effect until another gcode is sent that alters it.
Some gcodes work in concert with other things, for example, M558, M557, and G31 are used to configure the behaviour of G29 and G30.
Endstops are configured with M547 and interact with homing moves using G1 H1, and take values from M208 when an endstop is hit.
ell for instance i have two entries on M558 i haveM558.... P5 H5 f100 t2000
and
m558 558 P9 H5 F100 T4000so im assuming (dont remeber) i typed in the P 9 line and that added all the other stuff??
ops, -
Well if both of those lines are in config.g then the later one will take over the earlier one. At least if they both have the same parameters. If the earlier one has parameters that the second one didn't, it would carry over that setting from the first one. And in addition, for some commands, including M558 in later firmwares with multiple probe support, it may depend on which piece of hardware is being targeting, such as the probe type.
Example
M558 P9 H3 F100 T2000 A10 B1 M558 P9 H5 F60 T2000
If you sent those two commands in sequence, the resulting setting would be
M558 P9 H5 F60 T2000 A10 B1
This can actually be useful for modifying just a couple parameters when needed like in the homeall you can use this to have a single fast probe, and then a slower multi probe with
M558 A1 F400 ; Set single probing at faster feed rate G30 ; Do a single probe to home our Z axis M558 A10 F100 ; Set multi probing at slower feed rate G30 ; Probe again to get a more accurate position
So it is important to have some coding hygiene and keep your commands tidy and remove any duplicates.
so what i thing i did!!! no way i remeber, but i think when i added the p9 line it swiched a lot of things just not sure like stall, endstops and added bl touch
if im right in my assumptions i would remove the entre second line go back to P5 and redo the z sensor or inductive which is the P5 line????
If you're using a BLTouch you should use P9.
You can post your config.g if you want some clarity.
please
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes forward
M569 P1 S1 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwardsM569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
; M92 X79.7 Y79.6 Z400.4 E96 ; Set steps per mm
M92 X79.2 Y79.2 Z400.5 E96 ; Set steps per mmM566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y30000 Z300 E1500 ; Set maximum speeds (mm/min)
M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
M906 x950 Y950 Z850 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
; M208 X258.5 Y246 Z260 S0 ; Set axis maximaM208 X0 Y0 Z0 S1 ; Set axis minima
M208 X500 Y500 Z500 S0 ; Set axis maxima; Endstops
M574 X0 Y0 Z0 S1 ; Set endstops controlled by motor l; Z-Probe
; M558 P5 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
M558 P9 H5 F100 T4000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P500 X-42 Y-5 Z1.35 ; Set Z probe trigger value, offset and trigger height - is Nozzle hogerM557 X15:215 Y35:215 S20 ; Define mesh grid
M143 H0 S120 ; Set temperature limit for heater 0 to 80C
M305 P1 T100000 B4400 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 240C; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned offM106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
; Custom settings are not configured; BLTouch - Heaters
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch; Enable Bed Leveling
G29 S1 ; Enable Mesh Bed Leveling -
@ziggymanpopo said in code ???? o k then ???:
M574 X0 Y0 Z0 S1 ; Set endstops controlled by motor lPart of your problem might be that you have set it so you have no endstops.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
G29 S1 ; Enable Mesh Bed LevelingYou should not load the heightmap in config.g Move it to your slicer start gcode after homing with G28 instead.
using capasitive sensor
Ok, but M574 X0 Y0 Z0 means no endstop at all... You must tell it if it's at the high or low end of travel with 1 or 2.
Please read the M574 wiki entry
yup thats the heart of the problem i know most of the stuff that needs chainging but fearfull ill do more damage than good ... it was working and producing pretty good prints what i am doing might help you understand what i'm asking i have or what used to be a cr10-s5 duet 2 wifi with lots of upgrades
the ringing was pronounced. i installed a 16/05 ball screw ill change the steps to 6400 according to the math, but not until i get the y sw. to work again. stall worked fine until i upgraded to linear rails an a ball screw did not think stall would be good for the tork it provides
all that said i know its time to address my software issues ...im starting to get it sucks being a newbie lol. -
OK, well you need to specify at which end of the axis travel the endstop is going to be. M574 X1 Y1 for the low ends. Then use the S parameter to choose your switch type, either normally open or normally closed. Try with S1 and S2 and see which will show as triggered or not triggered in the machine properties tab.
How do you have the capacitive sensor wired? What kind of a switch does it act like?
changed the stops to M574 x1 y1 z1 s1 still they dont work
check this out when i type inM588 i get thisZ Probe type 9, input 0, invert no, dive height 5.0mm, probe speed 100mm/min, travel speed 4000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
isn't this the root of my evil ptoblem
im thinking i should type in m558 P5?????
No. The z probe has nothing to do with your endstops.
ok where did the stall feature come from then the docs say if stall is active endstops wont work im trying to understand did it com from M307
Stall detection as an endstop is defined by M574 S3.
M307 is to configure heater parameters. Not related.
What exactly is not working?
If you have changed the Y axis to use the ball screw, have you changed the steps per mm yet?
all 3 endstop limits limits let me reboot and ill try again
could my prob be in the 4 home files
; homeall.gG91 ; relative positioning
G1 S2 X0.2 Y0.2 Z0.2 ; Move all axis 0.2 mm, clear stall status
M98 Pdeployprobe.g ; deploy mechanical Z probe; x and y Sensor less homing
M400 ; make sure everything has stopped before we make changes
M915 X S2 Y S3 R0 F0 ; set X and Y sensitivity, do nothing when stall, unfiltered
M574 X1 Y1 S3 ; set endstops to use motor stall
G1 S2 Z10 F1200 ; lift Z
G1 S1 X-265 Y-260 F5000 ; move X and Y back, stopping at the end stop
G90 ; back to absolute mode;G1 X115 Y115 F12000 ; Move to center of bed and home Z
G1 X127 Y134 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bedM915 X S10 Y S10 R3 F0 ; set X and Y sensitivity to -0, when stall home XY and resume print, filtered so it takes 4 steps to figure out it has stalled
M98 Pretractprobe.g ; retract mechanical Z probe
what does a guy remove ?? replace???
