    Logic Level shifter for 12864 display on Duet 2 Wifi
    200
    16.5k
    • oliofundefined
      oliof
      ISTR that extra pin is for digital contrast control (the smart full graphics controller has a potentiometer for that) so it might need another option for M918 to set contrast ... likely adding some more memory requirements.
      But as long as there's no space in RAM that's likely moot anyways.
        dc42 administrators @oliof
        @oliof said in Logic Level shifter for 12864 display on Duet 2 Wifi:
        It's not for contrast control, it's just that the ST7567 controller chip needs a command/data input pin as well as data, clock and CS.
        • oliofundefined
          oliof
          Today I learned.
          That said, I'd be willing to carry a patch removing unnecessary kinematics for an unofficial unsupported build with ST7567 support to make space -- I already know how to do that. I should be able to keep the patch going in case it needs changes ...
          @dc42 I want to thank you a lot for even putting forward the consideration of including it; I also understand other features would be prioritized indefinitely.
          • antlobundefined
            antlob
            @oliof @dc42 @bearer
            First of all congratulations for the great job, I'm new to Duet 2 Wifi and have an LCD 12864 that came with my 3d printer (secKit Go) I also have the Paneldue 4,3". My first question is: Could I have both displays working at the same time? If I loose the SD card on the LCD 12864 would be fine since I have it on the Paneldue 4,3". What I would really like is to have the encoder operational on the LCD 12864. Is this doable? Many thanks in advance for your support.
            • oliofundefined
              oliof
              emerges from time spent away from 3d printing
              If the SecKit go panel is driven by an ST7920 it will work with the level shifter and a custom Duet2 Wifi firmware that makes space for the LCD12864 support today by cutting something else (for example a motion system you don't need on your printer like Hangprinter).
              AFAICS using an LCD12864 and PanelDue in parallel works. But then v3 PanelDues have the pins for an encoder and there will be support for it in a future release so maybe it's better to wait for that.
              submerges again
              • antlobundefined
                antlob
                v3 PanelDues
                Thanks @oliof for the reply. It does have the ST7920 so I I would need to connect the LCD to the CONN LCD on the Duet and add a level shifter following the schematics on the forum above skipping the SD Connector, rigth?. That does not seem hard but, my struggle is with the firmware, following Markus Scheck blog and the comments above in the fourm there are some libraries to be included and minor changes to be made to them. I've found this instructions for building https://github.com/Duet3D/RepRapFirmware/blob/dev/BuildInstructions.md of the @dc42 fork but ... I know it is a stupid question and sorry in advance, Where can I find the source libraries to make the bin file? My current version on the Duet 2 Wifi is 2.05.
                Thanks again for your time.
                • A Former User?
                  A Former User @antlob
                  @antlob Looks like they've started migrating to https://github.com/Duet3D/
                  btw, you need the gate function of the 7408 as well as its level shifting. (I used the TXS0108 as the enable pin mimicked the AND gate function.
                  antlobundefined 1 Reply Last reply Reply Quote 0
                  • antlobundefined
                    antlob @A Former User
                    Thanks for the tip @bearer, found them finally, is huge but I'll definitely try it. Just one question, if I only connect ENC_SW, ENC_A, ENC_B, BEEP on the Duet 2 CON_LCD to the EXP 1 and EXP 2 on the LCD 12864. Will it work? The CON_SD is used right know to support the SD on the PanelDue.
                    • A Former User?
                      @antlob said in Logic Level shifter for 12864 display on Duet 2 Wifi:
                      CON_SD is also needed to drive the display, it uses the SPI bus for both, which is why I opted to change things around so I could connect only CON_SD and have a functional display sans the encoder.
                      • antlobundefined
                        OK! So for what you say it is impossible to connect this LCD only from CON_LCD. I do not have the required knowledge to swap the SPI pins to CON_LCD, or maybe it is not even possible. Thank you, you saved me a lot of time!
                        • A Former User?
                          me the modified libraries to make the build?
                          I didn't modify any libraries, and the patch against RRF is up there somewhere, and I believe we included it on the easyeda page for the board as well.
                          I don't have access to the computer I built the firmware atm, but i found these locally, if you're prepared to recover by usb/bossa you could give it a try.
                          https://www.dropbox.com/s/g42b7gye964sd5e/Duet2CombinedFirmware_2.0.51_LCD8.bin?dl=1
                          https://www.dropbox.com/s/f7fjuu7f0wcf7dc/Duet2CombinedFirmware-rrf3-lcd.bin?dl=1
                            The RRF v3.02-dev branch now includes the changes needed to support ST7920 and ST7567 displays in the source code. Unfortunately the generated binary is too large if you enable SUPPORT_12864_LCD in the standard Duet2CombinedFirmware build. So something else will need to be done, perhaps one of the following:
                            • Strip out unused functionality
                            • Use separate builds for Duet Wifi and Duet Ethernet, so that only one set of network code is needed
                            • Remove the large font
                            • Change the optimisation options to optimise for space instead of speed, and use function-specific attributes on those functions where optimisation for speed is desirable
                            • antlobundefined
                              @bearer Many thanks! I'll make the circuit on a breadboard just to see if I can turn on the display.
                              • antlobundefined
                                antlob @dc42
                                @dc42 Many thanks for replying. In my case would be to build just for the Duet Wifi and discard the Ethernet but my concern really is that in order for me to use LCD 12864 I would need to sacrifice the SD card support on the Duetpanel and maybe the SD on the LCD 12864 cannot be read by the DWC. If by any chance I could read the card on the LCD panel then I would go for it but as you say a separate build for the Wifi and Ethernet should be made and I don't know how to do it.
                                  dc42 administrators @antlob
                                  I've changed the compiler options in the Duet2Combined build of RRF 3.02 to optimise for space instead of speed, and saved some space in a few other places, and it now fits. Sometime soon I will change it to include the 12864 support as standard and automatically disable the extra 2 stepper drivers if the display is enabled using M918. I haven't yet assigned the extra pin needed by 12864 displays with ST7567 controllers, or the extra pin needed for backlight control on some displays, but I plan to take those from CONN_LCD too - which is why I will disable both stepper drivers on the connector.
                                  antlobundefined 1 Reply Last reply Reply Quote 1
                                  • antlobundefined
                                    antlob @dc42
                                    @dc42 Great news, I'll wait and in the mean time I'll wire the hardware. Since I'm a rookie in this forum and the Duet, when you publish the change where do I find it? or how can I know that it has been published?
                                      The work I have done so far is on the v3.02-dev branch of the Duet3D RepRapFirmware repository, and I will publish the further changes there too.
                                      antlobundefined 2 Replies Last reply Reply Quote 0
                                      • antlobundefined
                                        antlob @dc42
                                        @dc42 Many thanks!
                                        • antlobundefined
                                          antlob @dc42
                                          @dc42 Hello! My intention was to first upload the 3.02 to the printer and later do the hardware. I have downloaded RepRapFirmware-3.02-dev.zip and copied it to the /sys folder, rebooted the machine but nothing happens. My firmware version continues to be 2.05.1. Since it is version 3.02 I assumed it would be the same as v3.0. What am I doing wrong? Please advice.
                                            That zip you downloaded is a source code zip, not a binary zip.
                                            You will need to upgrade to firmware 3.0 first, then you can upgrade immediately to 3.1.1. Sort out the changes to your config,g file, and by the time you have done that I should have a 3.2 alpha firmware build available.
