    Logic Level shifter for 12864 display on Duet 2 Wifi
    200
    16.5k
    • oliofundefined
      oliof
      emerges from time spent away from 3d printing
      If the SecKit go panel is driven by an ST7920 it will work with the level shifter and a custom Duet2 Wifi firmware that makes space for the LCD12864 support today by cutting something else (for example a motion system you don't need on your printer like Hangprinter).
      AFAICS using an LCD12864 and PanelDue in parallel works. But then v3 PanelDues have the pins for an encoder and there will be support for it in a future release so maybe it's better to wait for that.
      submerges again
      • antlobundefined
        antlob
        @oliof said in Logic Level shifter for 12864 display on Duet 2 Wifi:
        v3 PanelDues
        Thanks @oliof for the reply. It does have the ST7920 so I I would need to connect the LCD to the CONN LCD on the Duet and add a level shifter following the schematics on the forum above skipping the SD Connector, rigth?. That does not seem hard but, my struggle is with the firmware, following Markus Scheck blog and the comments above in the fourm there are some libraries to be included and minor changes to be made to them. I've found this instructions for building https://github.com/Duet3D/RepRapFirmware/blob/dev/BuildInstructions.md of the @dc42 fork but ... I know it is a stupid question and sorry in advance, Where can I find the source libraries to make the bin file? My current version on the Duet 2 Wifi is 2.05.
        Thanks again for your time.
        • A Former User?
          A Former User @antlob
          @antlob Looks like they've started migrating to https://github.com/Duet3D/
          btw, you need the gate function of the 7408 as well as its level shifting. (I used the TXS0108 as the enable pin mimicked the AND gate function.
          antlobundefined 1 Reply Last reply Reply Quote 0
          • antlobundefined
            antlob @A Former User
            Thanks for the tip @bearer, found them finally, is huge but I'll definitely try it. Just one question, if I only connect ENC_SW, ENC_A, ENC_B, BEEP on the Duet 2 CON_LCD to the EXP 1 and EXP 2 on the LCD 12864. Will it work? The CON_SD is used right know to support the SD on the PanelDue.
            • A Former User?
              @antlob said in Logic Level shifter for 12864 display on Duet 2 Wifi:
              CON_SD is also needed to drive the display, it uses the SPI bus for both, which is why I opted to change things around so I could connect only CON_SD and have a functional display sans the encoder.
              • antlobundefined
                OK! So for what you say it is impossible to connect this LCD only from CON_LCD. I do not have the required knowledge to swap the SPI pins to CON_LCD, or maybe it is not even possible. Thank you, you saved me a lot of time!
                • A Former User?
                  me the modified libraries to make the build?
                  I didn't modify any libraries, and the patch against RRF is up there somewhere, and I believe we included it on the easyeda page for the board as well.
                  I don't have access to the computer I built the firmware atm, but i found these locally, if you're prepared to recover by usb/bossa you could give it a try.
                  https://www.dropbox.com/s/g42b7gye964sd5e/Duet2CombinedFirmware_2.0.51_LCD8.bin?dl=1
                  https://www.dropbox.com/s/f7fjuu7f0wcf7dc/Duet2CombinedFirmware-rrf3-lcd.bin?dl=1
                    The RRF v3.02-dev branch now includes the changes needed to support ST7920 and ST7567 displays in the source code. Unfortunately the generated binary is too large if you enable SUPPORT_12864_LCD in the standard Duet2CombinedFirmware build. So something else will need to be done, perhaps one of the following:
                    • Strip out unused functionality
                    • Use separate builds for Duet Wifi and Duet Ethernet, so that only one set of network code is needed
                    • Remove the large font
                    • Change the optimisation options to optimise for space instead of speed, and use function-specific attributes on those functions where optimisation for speed is desirable
                    • antlobundefined
                      @bearer Many thanks! I'll make the circuit on a breadboard just to see if I can turn on the display.
                      • antlobundefined
                        antlob @dc42
                        @dc42 Many thanks for replying. In my case would be to build just for the Duet Wifi and discard the Ethernet but my concern really is that in order for me to use LCD 12864 I would need to sacrifice the SD card support on the Duetpanel and maybe the SD on the LCD 12864 cannot be read by the DWC. If by any chance I could read the card on the LCD panel then I would go for it but as you say a separate build for the Wifi and Ethernet should be made and I don't know how to do it.
                          dc42 administrators @antlob
                          I've changed the compiler options in the Duet2Combined build of RRF 3.02 to optimise for space instead of speed, and saved some space in a few other places, and it now fits. Sometime soon I will change it to include the 12864 support as standard and automatically disable the extra 2 stepper drivers if the display is enabled using M918. I haven't yet assigned the extra pin needed by 12864 displays with ST7567 controllers, or the extra pin needed for backlight control on some displays, but I plan to take those from CONN_LCD too - which is why I will disable both stepper drivers on the connector.
                          antlobundefined 1 Reply Last reply Reply Quote 1
                          • antlobundefined
                            antlob @dc42
                            @dc42 Great news, I'll wait and in the mean time I'll wire the hardware. Since I'm a rookie in this forum and the Duet, when you publish the change where do I find it? or how can I know that it has been published?
                              The work I have done so far is on the v3.02-dev branch of the Duet3D RepRapFirmware repository, and I will publish the further changes there too.
                              antlobundefined 2 Replies Last reply Reply Quote 0
                              • antlobundefined
                                antlob @dc42
                                @dc42 Many thanks!
                                • antlobundefined
                                  antlob @dc42
                                  @dc42 Hello! My intention was to first upload the 3.02 to the printer and later do the hardware. I have downloaded RepRapFirmware-3.02-dev.zip and copied it to the /sys folder, rebooted the machine but nothing happens. My firmware version continues to be 2.05.1. Since it is version 3.02 I assumed it would be the same as v3.0. What am I doing wrong? Please advice.
                                    That zip you downloaded is a source code zip, not a binary zip.
                                    You will need to upgrade to firmware 3.0 first, then you can upgrade immediately to 3.1.1. Sort out the changes to your config,g file, and by the time you have done that I should have a 3.2 alpha firmware build available.
                                    • antlobundefined
                                      antlob @dc42
                                      @dc42 Many thanks! Already with version 3.1.1, now updating my config.g file.
                                      • antlobundefined
                                        antlob @dc42
                                        @dc42 All finished, a little bug on the BLtouch, on the reboot the probe pin remains down, have to put it back up manually by a macro. Everything else works perfect.
                                        • Schmartundefined
                                          Schmart
                                          Please also note the thread I started about my working solution here.
                                          This is my own adaptation of RRF v3-dev code branch. It still needs a little work in terms of optimization and requires a NAND logic chip to invert the Chip Select (CS) signal if the default Maestro 12864 LCD pins are used. The extra A0/DC line that the ST7565/UC1701 requires is implemented with pin exp_0 on the Maestro.
                                          Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
                                            I've put some RRF 3.1 alpha binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. The 12864 display is not yet enabled in the Duet WiFi/Ethernet build because I still need to add the code to disable motors 10 and 11 when the 12864 display is configured.
