    Needing info on the toolboard harness end crimps.
    • Nuramoriundefined
      Nuramori
      I would like to terminate my motor cable to not require a splice to the harness that came with the duet3 toolboard I'm installing. I tried to find the proper wire end crimp I need to fit in the supplied harness shell. Is there a place I can find this, or short of that, can someone tell me the proper end to get? Much appreciated.
      • A Former User?
        A Former User
        https://www.duet3d.com/Duet3Toolboard1LC ?
        Looks like
        supply or heater? is 3.96mm VH
        motor is 2.0mm PH
        rest are 1.5mm ZH
        all from JST.
        Suppose https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Duet_Num_3 could be updated to reflect the new boards.
        dc42undefined 1 Reply Last reply Reply Quote 1
        • Nuramoriundefined
          Nuramori
          Thanks Bearer.
            dc42 administrators @A Former User
            @bearer said in Needing info on the toolboard harness end crimps.:
            Looks like
            motor is 2.0mm PH
            rest are 1.5mm ZH
            all from JST.
            That's all correct.
