    M104/G10 Temperature Threshold
    • Ray11
      Ray11 last edited by
      It seemed like currently, the default threshold for Duet is 1 degC. When the measured temperature is within 1 degC of the targeted temperature, the firmware will proceed to the next instruction. Is it possible to change the threshold to a larger value? I got some powerful fan directly blowing at the heater block. During tool change, when the fan turns on, the temperature fluctuates a bit. This fluctuation causes the system to wait until temperature stabilized. Increasing the threshold should reduce waiting time during tool change.
        M104 sets the temp and releases control. It doesn't wait.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M104_Set_Extruder_Temperature
        M109 waits to within 2.5c
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M109_Set_Extruder_Temperature_and_Wait
        G10 and M116 has the S parameter to specify the tolerance.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M116_Wait
