Arduino send data to duet
  • I'm using an arduino with thermistors attached to control fan speed for one of the fans cooling electronics. There are a couple of things I'd like to do:
    1. report 1-4 temperatures back to the duet that'd be viewable in the extra tab
    2. report if the fan is spinning to stall M81 S1
    I'm using a duet maestro and have a paneldue attached w/ 4 wire cable (it seems like the general advice is to talk to arduino with the paneldue port)
  • Also, if I could connect 3 more thermistors and another relay that would negate the above question. I have e0temp available but I don't think there's anywhere for the other 3 thermistors or the relay for the fan.
  • @jphilly said in Arduino send data to duet:
    If you have unused Duet analog temperature sensor inputs, theoretically you could use digital resistors controlled by the arduino to feed the temperature at some accuracy level into the duet.
    https://www.analog.com/media/en/technical-documentation/data-sheets/AD5272_5274.pdf
    (or a servo attached to a mechanical potentiometer).
  • @zapta I just want to turn the fan off and on so assuming my relay works with a 3.3v expansion pin that's good, thanks.
