    PanelDue 7i blank screen
    PanelDue
    • ronateahundefined
      ronateah
      I bought the PanelDue 7i from filastruder and it has been running my rail core with no issues for about a month and it just died with for seemingly no reason. it is a blank screen. not white. there is a white led on the bottom of the screen. I am wondering if it possible for do this withe erase button. any suggestion would be appreciated.
        If you follow this does it show up as a device on your computer?
        https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
        • ronateahundefined
          ronateah
          yes i do see the device
            And are you able to follow the instructions to flash the latest firmware?
            And if that happens, does the screen return to normal operation?
            ronateahundefined 1 Reply Last reply Reply Quote 0
            • ronateahundefined
              ronateah @Phaedrux
              @Phaedrux said in PanelDue 7i blank screen:
              Thank you so much that got it running again. Can you tell me the purpose of the erase and reset buttons. Can i get into trouble with these buttons
              • aidarundefined
                aidar
                Erase button does what it says, it erases, or should i say deletes firmware. Reset button just resets panel, that means restarts it. If you accidently push ( or let say enclosure does that) erase button, then you need to flash firmware again.
                • ronateahundefined
                  ronateah
                  thanks again
