    Home Z several times and get average
    • simplesimsonundefined
      simplesimson
      setup: CoreXY Using dc42 IR probe for Z endstop + leveling
      I´m having trouble with my IR Probe it does create inconsistent values.
      To get it printing anyways i want to home z 5 times and get an average value of the 5 homings. How can I do this?
      G30 S-1 outputs
      14:43:13Stopped at height 0.498 mm
      14:43:03Stopped at height 0.505 mm
      14:42:54Stopped at height 0.500 mm
      14:42:45G30 S-1
      Stopped at height 0.502 mm
        See the M558 A and S parameters. A5 S0 should do what you want.
        simplesimsonundefined 1 Reply Last reply Reply Quote 0
          simplesimson @dc42
          @dc42 hey 🙂 thanks for your answer
          my M558 (config.g) looks like this:
          M558 P1 H2.5 F120 T9000 I0 R1 A5 S0.1
          But when doing G28 at the start of the print it doesnt check 5 times.
          It just uses my homeall.g
          can i define a special M558 in homeall.g?
            dc42 administrators @simplesimson
            @simplesimson said in Home Z several times and get average:
            Does it probe twice? You've set the tolerance to 0.1mm (S parameter), so it will only probe twice if the two readings differ by no more than 0.1mm. I suggested you use S0.
