    Error: Homing failed, also no print time estimation given
    Duet Web Control
    • Dezdoghoundundefined
      Dezdoghound
      I've got two issues that may be related. The first is that when I do a G28, even though it homes successfully, it gives "Error: Homing failed" back in the console. My homing routine is as follows:
      • Stall detect homing for X and Y
      • Move to position to pick up a probing module
      • Call a macro to pick up the probe and use G1 -999 H1 to move Z until the module is picked up
      • Change probe type and move to probing position
      • Probe the bed with G30
      • Use a macro to put the probe module back down
      Could it be something to do with using macros?
      My second issue is that the print status then goes to 100% complete immediately and gives no estimations for finishing time.
        Post your config.g and homeall.g
        What firmware? What board?
        Dezdoghoundundefined 1 Reply Last reply Reply Quote 0
          Dezdoghound @Phaedrux
          @Phaedrux
          This is with a duet 2 wifi 1.02 running firmware 2.02, web interface 1.21
          ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 20:20:59 GMT+0100 (British Summer Time)
          G90                                 ; Send absolute coordinates...
          M83                                 ; ...but relative extruder moves
          M667 S1                             ; Select CoreXY mode
          M550 PHypercube                     ; Set machine name
          M552 S1
          M586 P0 S1                          ; Enable HTTP
          M586 P1 S0                          ; Disable FTP
          M586 P2 S0                          ; Disable Telnet
          M569 P0 S1                          ; Drive 0 goes forwards
          M569 P1 S1                          ; Drive 1 goes forwards
          M569 P2 S1                          ; Drive 2 goes forwards
          M569 P3 S1                          ; Drive 3 goes forwards (was backwards pre 6/4/19)
          M350 X16 Y16 Z16 E16 I1             ; Configure microstepping with interpolation
          M92 X80 Y80 Z400 E412               ; Set steps per mm was 420 original, now 412 of 26/04/19
          M566 X1000 Y1000 Z50 E3000          ; Set maximum instantaneous speed changes (mm/min)   was 400x 400y 15/12 e was 150 as of 15/12   z was 12 as of 10/01/20
          M203 X30000 Y30000 Z1000 E18000        ; Set maximum speeds (mm/min) z was 500 as of 12/04/20
          M201 X1000 Y1000 Z60 E3000            ; Set accelerations (mm/s^2) was X1000 Y1000 z was 120 as of 10/01/20
          M906 X1200 Y1200 Z1200 E1500 I30     ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30                             ; Set idle timeout
          m572 d0:1 s0.0				;add pressure advance if wanted
          m584 z2
          M208 X0 Y0 Z0 S1                   ; Set axis minima
          M208 X200 Y200 Z200 S0              ; Set axis maxima
          M574 X1 Y2 S3                       ; Set endstops controlled by motor load detection
          M591 d0 p1 c3 s1   ;enable filament run out for e0, low when present, extruder e0 endstop
          m558 p5  I1 H3 F200 T18000 R0.1 b0 for picking up probe module
          G31 P50 X-27 Y17 z23.75            ;Set Z probe trigger value, offset and trigger height.
          M557 X0:173 Y17:200 S30          ; Define mesh grid
          M305 P0 T100000 B4138 C0 R4700      ; Set thermistor + ADC parameters for heater 0
          M143 H0 S120                        ; Set temperature limit for heater 0 to 120C
          M305 P1 T100000 B4138 C0 R4700      ; Set thermistor + ADC parameters for heater 1 (was temp. 3950)
          M143 H1 S280                        ; Set temperature limit for heater 1 to 280C
          M106 P0 S0.0 I0 F100 H-1           ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on fan at 50%
          M106 P1 S0.0 I0 F100 H-1              ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P2 S255 I0 F500 H-1              ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 D0 H1                       ; Define tool 0
          G10 P0 X0 Y0 Z0                     ; Set tool 0 axis offsets
          G10 P0 R0 S0                        ; Set initial tool 0 active and standby temperatures to 0C
          M570 H1 P10 T15
          m501 ;yes they are
          My homing routine is as follows. I've indented the macros that are called:
          M915 Y S5 R0 F0 ;y homes first to ensure that X homes centrally
          M915 X S5 R0 F0
          M400
          M574 Y1 S3
          M913 X75 Y75
          G91
          G1 S1 Y-700 F4000
          G90
          M400
          M913 Y100
          G1 y100 f6000
          M915 X S5 R0 F0  ; x home
          M400
          M574 X1 S3
          M913 X75 Y75
          G91
          G1 S1 X-700 F4000
          G90
          M400
          M913 X100
          G1 X0 F6000
          M915 X S5 R0 F0
          M400
          M574 Y1 S3
          M913 X75 Y75
          G91
          G1 S1 Y-700 F4000
          g92 y20
          G90
          M400
          M913 Y100
          G28 Z
          ####### G28 Z ########
          m98 P"/Macros/pick_up_probe"
          ########## pick_up_probe ######
          G92 Z90 ;set Z height so that axis will move unhomed
          g91
          G1 Z10 F500 ; drop Z so module can be picked up
          G90
          g1 X8.1 Y169 F30000 ;move to probe pickup
          m574 z1 s2 ;configure endstop type for switch
          m558 p5  I1  F100 T6000 R0.6 b0 ;configure probe for picking up module
          G1 Z-999 F150 H1 ;dive z until picked up module
          G91 ;relative moves
          G92 Z30 ;set z axis to rough z position
          G1 Y22 F300 ;remove probe from holder
          G1 Z38 F2000 ;drop z to account for new probe height
          G90 ;absolute moves
          G1 X100 Y100 f30000 ;move to probe point
          M558 p8 I0 H1.5 F1000 T18000 R0 b0 ;configure probe for probing
          G30 ;do coarse home
          ######back to G28 Z#####
          m300 s880 p100 ;beep to signal probe contact
          g4 p120 ;dwell to wait for beep
          m558 f50 ;reduce feed rate for fine probe
          g30 ;probe z
          m300 s880 p100 ;beeps again
          g4 p200
          M558 F600 ;put feed back to normal
          ;G29 S0 mesh level if wanted
          m98 P"/Macros/put_down_probe"
          ########### put_down_probe #########
          G1 Z27 ;move to Z height
          G1 X40 Y185 f30000 ; go to probe put down position, avoiding the probe module (hence two individual moves)
          G1 X8.1 f30000
          G1 Z3.5 F600 ;move to z height for module put down
          G1 Y180 F200 ;feed slowly into probe holder
          G1 Y169 F100
          G1 Z25 F200 ;increase Z to drop probe
          g1 x100 y100 f6000
          #####end of put_down_probe####
          #####end of G28 Z ######
          #####end of home all #####
          I appreciate there are a lot of lines in there! Thanks for your help!
            May I ask that you update to 2.05.1 and update the DWC as well. You're quite out of date and any issues may have already been fixed.
              @Phaedrux is 2.05.1 the latest firmware? 3.01 is the last one on the github?
                2.05.1 is the last of the RRF2 stable line. 3.01 is in active development and will require some changes to your config.g and possibly other files.
                For the time being, please test with 2.05.1. Take a look at the release notes for the versions between 2.02 and 2.05.1.
