    Macro to assist with using object cancellation
    Beta Firmware
    941
      RepRapFirmware 3.07-RC6 and RC7 support object cancellation if the GCode file contains object labels (e.g. as generated by Prusa Slicer if you select the "Label objects" option). As there isn't yet an object cancellation interface in Duet Web Control, here are the contents of a macro file I use called "List objects on build plate" that I use to help identify the object that I want to cancel.
      if job.build == null || #job.build.objects == 0
        echo "No objects"
      else
        echo #job.build.objects,"objects on build plate"
        while iterations < #job.build.objects
          echo "Object",iterations,job.build.objects[iterations].name
          echo "  X",job.build.objects[iterations].x[0],"to",job.build.objects[iterations].x[1]
          echo "  Y",job.build.objects[iterations].y[0],"to",job.build.objects[iterations].y[1]
      • gtj0undefined
        gtj0
        For those of us who don't use Prusa Slicer, have you got some sample gcode that will qualify as an object label?
          dc42 administrators @gtj0
          @gtj0 said in Macro to assist with using object cancellation:
          This is how Prusa Slicer labels object changes:
          G1 X-11.839 Y8.798 E0.11133
          G1 X-11.952 Y8.775 E0.00373
          G1 X-13.329 Y7.855 E0.05335
          G1 X-13.955 Y7.230 E0.02849
          ; stop printing object TrivetFoot.stl id:0 copy 1
          ; printing object TrivetFoot.stl id:0 copy 2
          G10 ; retract
          G1 X-3.381 Y-9.123 F7800.000
          G11 ; unretract
          G1 F1800.000
          G1 X-4.367 Y-10.600 E0.05569
          Any prime towers or other non-object features would be printed between the "stop object" and "start object" labels. The skirt is printed before the first "start object" label.
          Object labels added by Cura should also be recognised by RRF, but I have read that Cura uses a separate object label for support and that could be problematic.
          You can also label objects using M486, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M486_Object_cancellation.
          • gtj0undefined
            gtj0
            Cool! I'll be trying it out this weekend.
              If you decide to copy the Prusa approach, then RRF doesn't need the object name following "; stop printing object" because it already knows it.
              The whole of the remaining text on the line after "; printing object " is treated by RRF as the object name. I suggest you include at least the name of the STL file and the copy number. Similarly if you use M486 to label the objects and you provide the A parameter.
              ChrisPundefined 1 Reply Last reply Reply Quote 0
              • ChrisPundefined
                ChrisP @dc42
                Just been having a play with this to see how it works. I've just done a slice of 4 instances of one object using PrusaSlicer and enabled labels, but it doesn't seem to detect any objects. The file otherwise prints fine.
                Here's a snip of the file showing, like your example, the start and stop labels for two objects:
                G1 X78.145 Y74.891 E0.24387
                G1 X78.380 Y75.460 E0.05244
                G1 X78.563 Y75.795 E0.03248
                G1 X78.846 Y76.192 E0.04154
                G1 X79.648 Y76.996 E0.09671
                ; stop printing object Marvin_KeyChain.STL id:0 copy 3
                ; printing object Marvin_KeyChain.STL id:0 copy 1
                G1 F7200.000
                G1 X78.846 Y76.192 E-0.44953
                G1 X78.563 Y75.795 E-0.19310
                G1 X78.380 Y75.460 E-0.15095
                G1 X78.145 Y74.891 E-0.24374
                G1 X80.170 Y76.916 E-1.13350
                G1 X80.540 Y76.890 E-0.14686
                G1 X80.701 Y76.844 E-0.06624
                G1 X78.171 Y74.315 E-1.41607
                G1 E-5.82113 F3000.00000
                G1 Z0.500 F9000.000
                G1 X42.461 Y73.912
                G1 Z0.200
                G1 E9.62113 F3000.00000
                G1 F900.000
                G1 X42.296 Y74.641 E0.06086
                Running the macro from post #1 returns "No objects", and the OM returns this for job.build:
                  "key": "job.build",
                  "flags": "",
                  "result": {
                    "currentObject": -1,
                    "m486Names": false,
                    "m486Numbers": false,
                    "objects": []
                Not sure if there's something I'm missing? Using 3.0.1-RC11 w/SBC.
                  Were you printing that file when you ran the macro? Object names are only added to the list as the machine starts printing them.
                  botundefined ChrisPundefined 2 Replies Last reply Reply Quote 0
                  • botundefined
                    bot @dc42
                    If that is the case, would it be possible to add support for pre-labeling the objects in the header/comment area of the Gcode file? That way, you could start a print and cancel an object right away even if that object had not been "encountered" yet by the gcode interpreter.
                    *not actually a robot
                    • ChrisPundefined
                      ChrisP @dc42
                      @dc42 said in Macro to assist with using object cancellation:
                      At the time I ran the macro and the M409 I'm pretty certain that at least 1 layer of all four objects had been printed. However, its a quick print so I'll try again just to double check...
                      @bot said in Macro to assist with using object cancellation:
                      Assuming that objects just get added to the object list as/when they are first encountered, this should be easy to do with a post process. What would be neat is if running a simulation (or post-print) could then prepend this to the g-code file.
                      edit: I've just checked and yes, I get the same results as above even after n>0 layers of all parts have been printed.
                        dc42 administrators @ChrisP
                        Thanks. It sounds to me that DCS isn't yet passing the comments on to RRF.
                        • ChrisPundefined
                          ChrisP @dc42
                          One for @chrishamm, I guess then.
                          To get around this issue, I post-processed the file to replace PrusaSlicer's labels with M486 commands and can now see them fine in the OM 🙂
                          However, the macro still has an issue as I get the following error when I run it:
                          I've made sure that all the lines are inset correctly and I've also found that if I insert an extra echo iterations on line 6 then that line works but subsequent ones fail and terminate the macro
                          If I then comment the last 3 lines, but leave my addition, I see the expected output in the console, so the issue seems to be when "iterations" is used as an argument.
                          Is this perhaps another issue with the way DCS is passing the comments?
                          • OwenDundefined
                            OwenD
                            I found that if you pass M291 using anything but the S3 parameter, or use M117, then you get that error about iterations being called while not being in a loop.
                            This is my code which works.
                            Cura calls all supports "NON MESH" so I haven't worked out how to post process to identify what support goes with what object yet
                            if !{state.status="processing"}
                            	M291 P"Not printing" R"Error" S1 T7
                            	abort "Not printing"
                            if {job.layer<2}
                            	M291 P"Not all objects may be detected yet.  Continue?" R"Warning" S3
                            	G4 S0.5
                            if {(#job.build.objects=null) || (#job.build.objects=0)}
                            	M291 P"No objects detected.  Check slicer or wait till end of first layer" R"Error" S2
                            	;abort "No objects"
                            ;if {(job.build.currentObject=null) || (job.build.currentObject=-1)}
                            ;	M291 P"Current print move is not a print object" R"Not a print object" S2
                            ;	abort "not a print object"
                            	if job.build.objects[ iterations ].cancelled
                            		echo "Obect " ^ iterations ^ already cancelled
                            		continue
                            	M291 P{(job.build.objects[iterations].name)} R"Delete?" S3
                            	;M486 P{iterations}
                            	G4 S1
                            echo "Finished"
                            • ChrisPundefined
                              ChrisP @OwenD
                              @OwenD
                              Interesting. What's your Duet setup? For now I was just starting with @dc42's macro as I assumed it should work for at least whatever setups he has. Have you tried this one & did it work for you?
                              OwenDundefined 1 Reply Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @ChrisP
                                @ChrisP said in Macro to assist with using object cancellation:
                                @OwenD
                                Board: Duet 2 WiFi (2WiFi)
                                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC11 (2020-04-30b3)
                                Duet WiFi Server Version: 1.23
                                Duet Web Control 2.1.6
                                I have run it and it works.
                                I'm just running a test with supports (sliced in Cura)
                                I'm not sure if I can identify the supports and as they'll be outside the X,Y of the object it might fail.
                                Will report back shortly
                                • OwenDundefined
                                  OwenD
                                  As I suspected, in Cura at least the supports aren't identified as objects by RRF
                                  That will require some post processing to get working (or the Cura devs to change their code)
                                  However the code does cancel the obects.
                                  NOTE: THERE WAS A SYNTAX ERROR IN THE ABOVE CODE
                                  Corrected code here
                                  if {job.layer<2}
                                  	G4 S0.5
                                  	;abort "No objects"
                                  	echo "check object " ^ iterations + 1
                                  		echo "Obect " ^ iterations ^ "already cancelled"
                                  		G4 S2
                                  		continue
                                  	M486 P{iterations}
                                  	G4 S2
                                  echo "Finished"
                                  • ChrisPundefined
                                    ChrisP
                                    I have just tried @dc42's macro with my system setup in standalone mode rather than the D3+SBC setup I tried yesterday and can confirm that it works fine & as intended.
                                    So I guess that's a bug in the way DCS handles the "iterations" variable in meta commands?
                                    @OwenD
                                    Thanks for sharing your macro, it covers off a couple of edge cases from a user perspective when displaying details 👍
                                    • OwenDundefined
                                      OwenD @ChrisP
                                      @OwenD
                                      No Problem.
                                      My macro won't work as it should until there's a third option for M291 that will allow us to skip over objects.
                                      At present you can't cancel object two until you have done object one.
                                      • chrishammundefined
                                        chrishamm administrators @ChrisP
                                        @ChrisP This will be fixed in the next versions. For now, you can work-around this problem by putting iterations into curly brackets. Something like job.build.objects[{iterations}].x[0] should work.
                                        The next DCS version will send whole line comments to RRF, too.
                                        Duet software engineer
