SOLVED M122 gives no output since DWC 2.1.x
since 2.1.x M122 does not give any output on my Duet 2 Wifi. I am on RC8 and 2.1.3.
No error and no output.With DWC 1.x and 2.0.7 everything is working fine so far.
That's odd, because that combination is working for me. I presume you are sending M122 from the Console of DWC? Does this problem happen immediately after startup, or only after the printer has been running for some time?
You can run DWC 1.22.6 if you had it installed on your SD card before you upgraded, by appending /reprap.htm to the IP address in the browser address bar. If you do that, does M122 work?
Yes through Konsole and same behavior when I press diagnostic button in the settings.
Already tried to reset DWC but doesn't help.
This is what I get:
@dc42 said in M122 gives no output since DWC 2.1.x:
Yes on 1.22.6 I get normal M122 output
@smoki3 said in M122 gives no output since DWC 2.1.x:
Thanks. I've asked @chrishamm to look into this.
@dc42 ok thanks
Just a short feedback, on 2.1.4 it is still not working
It's fixed now with RC12
