    Potenial Bug in M106?
    • JBiscundefined
      JBisc
      I observed a potenial bug in the fan function M106.
      If I change the PWM output from 0 to a value X, the PWM seem to make something like this:
      0%PWM --> 100%PWM for 100-200ms --> x%PWM forever
      So there is a small "burst/impulse".... Is this intended?
      Config:
      M950 F1 C"out8" Q500                         ; create pump 1 on pin out8 and set its frequency
      M106 P1 S0 H-1
      Change of PWM by:
      M106 P1 S1.0
      PS: Where is the best place to report potenial bugs? Here in the forum or in the Repository?
      My Setup: Duet 3 MB6HC Main Board with attached RPI
        jay_s_uk
        That's intended.
        Add B0 to not have it blip
        JBiscundefined 1 Reply Last reply Reply Quote 0
        • JBiscundefined
          JBisc @jay_s_uk
          @jay_s_uk Thanks! I still can't believe that somebody implemented 100ms as default.....
            jay_s_uk
            @JBisc
            Some fans are stubborn and don't work well with PWM. The blip is intended to kickstart them before slowing the speed
