    my second raspberry has just passed away
    Duet Web Control
    9
    102
    5.6k
    • spllgundefined
      spllg
      i am using raspberries for quit a few years now and never had any problems. now it seems a second raspberry running dwc, connected to a duet3 has just passed away. the sd card seems to be intact.
      i'm close to giving up using duet3 but i'm willing to give standalone duet3 a try. is there any howto to implement this configuration?
      • A Former User?
        A Former User @spllg
        @spllg said in my second raspberry has just passed away:
        pretty much just like the Duet 2 Ethernet setup, take your existing config.g add M552 S1 and move it to the first (or only) fat32 partition along with DWC files etc.
        edit: curious as to what would cause the Pi to die, can you add some high res pictures of them, or maybe get them to someone for an "autopsy" of sorts?
        • spllgundefined
          spllg
          there are no visible damages at the rpi. it just stopped working ant won't boot. just the same as the first died rpi. i bought a new rpi connected it to the duet3, inserted the sd-card. the rpi booted and worked fine for about 2 months until it died yesterday.
          see also https://forum.duet3d.com/topic/13956/is-the-duet-3-board-able-to-kill-an-attached-raspberry?_=1587368277091 .
          as i do not know what you mean by 'the DWC files etc', could you provide a reference?
          is it possible to connect the duet3 via usb to an rpi? this would enable me to control the duet using wifi via the rpi by means of octoprint.
            Are you powering the Pi from the Duet, or independently? Is it possible that you have created a ground loop, either by powering the Pi independently or by connecting something else to the Pi? See https://duet3d.dozuki.com/Wiki/USB_ground_loops.
            • spllgundefined
              spllg
              i am powering the duet 5v from the rpi via usb (internal 5v enable, 5v->sbc and sbc->5v are open) - a configuration which has been working fro ~2 months.
              btw.: tried sbc->5v (internal 5v enable open) but this did not work.
              dc42undefined Danalundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @spllg
                Odd, that should have worked.
                Does the PSU that powers the Pi use a mains ground pin? If so then you may have a ground loop, and you should power the Pi PSU and the Duet PSU and nothing else except Pi peripherals from the same power distribution block.
                • spllgundefined
                  spllg
                  it has been working for ~2 months
                  the psu that powers the pi dues not use a mains ground pin.
                  • A Former User?
                    ah, i thought you might have been using previous duets
                    https://duet3d.dozuki.com/Wiki/SD_Card
                    https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                      droftarts administrators @spllg
                      @spllg I've updated the SD card page, showing how to set up a new SD card for Duet 2 Wifi/Ethernet/Maestro and Duet 3. See: https://duet3d.dozuki.com/Wiki/SD_Card
                      spllgundefined 1 Reply Last reply Reply Quote 0
                      • spllgundefined
                        spllg @droftarts
                        @droftarts , @bearer thanks - i replaces config.g, .. with my customized versions and connected the duet with a cable to my network -> it prints.
                        but the issue is not solved. i think if i would install a new rpi it will die after a whils.
                        droftartsundefined arhiundefined 2 Replies Last reply Reply Quote 0
                          @spllg Which Raspberry Pi model? Anything else connected to the Pi? Trying to build up a picture of voltage/current issues, as has been reported in this other thread: https://forum.duet3d.com/topic/15709/undervolts-on-pi
                          • spllgundefined
                            spllg
                            rpi 4b with a display ( https://www.amazon.de/-/en/gp/product/B07YZ3ZVTW/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1 ), nothing else.
                            • arhiundefined
                              arhi @spllg
                              @spllg I'd love to get my hands on that pi to figure out why they died, I guess I'm not the only one :). Are those RPI 3B or ?
                              • arhiundefined
                                arhi
                                ah rpi4, have you tried powering it trough the 5V on the header and not trough the usb ? (stand alone, not connected to duet)
                                • spllgundefined
                                  spllg @arhi
                                  @arhi i have powered the pi from the duet using the header but did not succeed powering the duet from the rpi using the header.
                                  gtj0undefined 1 Reply Last reply Reply Quote 0
                                  • spllgundefined
                                    spllg @arhi
                                    @arhi
                                    i'd love to get my hands on that pi to figure out why they died, I guess I'm not the only one :). Are those RPI 3B or ?
                                    would you like to buy it?
                                    btw: duet 3 running in stand alone mode seems to over extrude quite a bit - at least my extrude settings ceased to work - had to lower it to 80%.
                                    arhiundefined 1 Reply Last reply Reply Quote 0
                                    • arhiundefined
                                      arhi @spllg
                                      Yes, would be an interesting project to figure out why it died, but it is impossible to get anything in .rs now due to quarantine and police hour. Let's discuss this after this #%$^^&_#@ is over, I'm def. interested.
                                      • gtj0undefined
                                        gtj0 @spllg
                                        Do you have both the 5V->SBC and the SBC->5V pins jumpered? They both need to be connected to power the Duet from the SBC.
                                        • Danalundefined
                                          Danal @spllg
                                          You guys discussed this a little above, and then moved on. This absolutely will not work (as Dave pointed out). The fact that it does work for @spllg would seem to be the key to whatever is killing these.
                                          As a "cold read" bystander of this thread, I believe you guys should go back and dive into this quite a bit more.
                                          spllgundefined A Former User? 2 Replies Last reply Reply Quote 2
                                          • spllgundefined
                                            spllg @Danal
                                            @Danal sorry, i should have written
                                            i am powering the duet 5v from the rpi via usb (internal 5v open, 5v->sbc and sbc->5v are open)
                                            instead of
                                            if it is not possible to 5v-power the duet using the usb port, how can i 5v-power the duet except from the 24v psu by means of internal 5v enable?
