    E-Steps calibrated but still overextrusion
    • maroonds
      maroonds last edited by
      Hi! First of all my setup: Ender 3, Duet Maestro, Hemera, Bltouch and new motors for Xyz from ldo.
      How I check my steps/mm: I take my calipers and mark the filament 12cm before the entrance to the extruder. Then I let my printer extruder 100mm and check if 2 cm is left and adjust my steps/mm accordingly.
      My current value is 397 steps per mm which is quite normal but when I print a single cube in Simplify3D to calibrate my flow I have to set it to 90% to get the wall-thickness that I set in the slicer.
      When I calibrate my flow in Prusaslicer I get a flow 98% which is normal.
      However, when I then try to print something with that flow my prints look awfully over extruded.
      I also get no strings with only 0.1 mm of retraction, so I guess something must be messed up.
      Any help is greatly appreciated.
        Try this technique.
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
        maroonds 1 Reply Last reply Reply Quote 0
        • maroonds
          maroonds @Phaedrux last edited by
          @Phaedrux
          I already tried this, but I still get this weird phenomenon.
