    Stuck in spin loop
    706
    • Arnaud Sundefined
      Arnaud S
      I have a bug when I ask for the origin in X, Y, Z. And sometimes the printer stops during printing.
      I have been on the problem for 4 days.
      Can you help me ? Thks
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC8 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S8-6J1DJ-3SD6M-1SKBFUsed output buffers: 3 of 24 (6 max)
      Static ram: 28052
      Dynamic ram: 92416 of which 20 recycled
      Exception stack ram used: 256
      Never used ram: 10328
      Tasks: NETWORK(ready,836) HEAT(blocked,1468) MAIN(running,1912) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:01:34 ago, cause: power up
      Last software reset time unknown, reason: Stuck in spin loop, spinning module GCodes, available RAM 9920 bytes (slot 3)
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20002eac Task 0x5754454e
      Stack: 00456b3b 0045a492 61070000 4655e000 40cabc00 00000000 00000000 00000000 00000000 00000000 00000000
      Error status: 0
      Free file entries: 10
      MCU temperature: min 34.4, current 36.3, max 36.7
      Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-04-21 12:16:22
      Cache data hit count 168151866
      Slowest loop: 5.03ms; fastest: 0.12ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 39.85ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address cc:50:e3:15:07:f2
      WiFi Vcc 3.36, reset reason Unknown
      WiFi flash size 4194304, free heap 24200
      WiFi IP address 192.168.6.40
      WiFi signal strength -71dBm, reconnections 0, sleep mode modem
        Please explain what you mean by "when I ask for the origin in X, Y, Z".
        • Arnaud Sundefined
          Arnaud S
          This post is deleted!
            From your diagnostic report, it appears that the firmware is stuck waiting for a command to the SD card controller to complete. Possible causes might be:
            • Faulty SD card
            • SD card socket not properly soldered to the Duet PCB
            • Faulty microcontroller, or another type of hardware fault
            I am happy to approve warranty replacement immediately if you wish. However, to help us understand the problem, can you post a high resolution photo of the back of the SD card socket, so that we can see if the pins there are properly soldered down?
            If you have a spare SD card, you could try using that one instead, after copying all the files to it from the original SD card.
            • Arnaud Sundefined
              Arnaud S
              You are probably right, it comes from the SD card.
              Since the last message, I focused on complete reconfiguration of the card with your documentation.
              I installed the latest version 3.01RC9 of the firmware and check all the lines in the config.g file.
              The motors, heaters etc are all well configured and the axes are really precise.
              I changed the SD card to an 8GB Class 10 HCI EMTEC.
              But the problem I arrive at the same result, during printing the printer stops! A message (from the new firmware) informs me that it cannot read the SD card.!
              Stop During Printing.jpg Photo Support SD CARD 2.jpg Photo Support SD CARD 1.jpg Message.png M122 of last bug.txt All connections Card.jpg
              M122 of last bug
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC9 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3S8-6J1DJ-3SD6M-1SKBFUsed output buffers: 3 of 24 (11 max)
              Static ram: 28044
              Dynamic ram: 93324 of which 24 recycled
              Exception stack ram used: 504
              Never used ram: 9176
              Tasks: NETWORK(ready,116) HEAT(blocked,1228) MAIN(running,1832) IDLE(ready,80)
              Last reset 01:33:44 ago, cause: software
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 9176 bytes (slot 1)
              Error status: 8
              SD card longest block write time: 0.0ms, max retries 3
              MCU temperature: min 41.6, current 42.4, max 44.1
              Supply voltage: min 23.8, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 61/160
              Driver 1: standstill, SG min/max 22/172
              Driver 3: standstill, SG min/max 0/1023
              Date/time: 2020-04-23 14:53:23
              Slowest loop: 1577.63ms; fastest: 0.13ms
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 145, MaxWait: 81521ms
              === MainDDARing ===
              Scheduled moves: 0, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 4  CDDA state: -1
              === AuxDDARing ===
              Segments left: 0
              === Network ===
              Slowest loop: 190.69ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              - WiFi -
              WiFi flash size 4194304, free heap 21496
              WiFi signal strength -68dBm, reconnections 0, sleep mode modem
              Socket states: 4 0 0 0 0 0 0 0
              Config.g
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Apr 21 2020 23:20:22 GMT+0200 (heure d’été d’Europe centrale)
              M550 P"iPrint"                                     ; set printer name
              M586 P1 S1                                         ; enable FTP
              M586 P2 S1                                         ; enable Telnet
              M569 P0 S1                                         ; physical drive 0 goes forwards
              M569 P1 S1                                         ; physical drive 1 goes forwards
              M569 P2 S1                                         ; physical drive 2 goes forwards
              M569 P3 S1                                         ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                                   ; set drive mapping
              M92 X79.81 Y79.92 Z402.30 E92.60                   ; set steps per mm
              M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
              M203 X3000.00 Y3000.00 Z240.00 E2700.00            ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100.00 E3000.00              ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
              M84 S10                                            ; Set idle timeout
              M208 X295 Y300 Z400 S0                             ; set axis maxima
              M574 X1 S1 P"!xstop"                               ; configure active-high endstop for low end on X via pin !xstop
              M574 Y1 S1 P"!ystop"                               ; configure active-high endstop for low end on Y via pin !ystop
              M574 Z1 S1 P"!zstop"                               ; configure active-high endstop for low end on Z via pin !zstop
              M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:280 Y15:285 S20                           ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
              M143 H0 S95                                        ; set temperature limit for heater 0 to 95C
              M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
              M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
              ; Heater PID parameters
              M307 H0 A27.8 C179.1 D1.7 S1.00 V24.1 B0           ; Plateau
              M307 H1 A498.0 C149.8 D8.2 S1.00 V24.1 B0          ; Buse
              M950 F0 C"fan0" Q50                               ; create fan 0 on pin fan0 and set its frequency
              M106 P0 C"FAN PLATEAU" S0 H-1                      ; set fan 0 name and value. Thermostatic control is turned off
              M950 F1 C"fan1" Q50                               ; create fan 1 on pin fan1 and set its frequency
              M106 P1 C"FAN BUSE" S0.45 H1 T150                   ; set fan 1 name and value. Thermostatic control is turned on
              M563 P0 S"Buse" D0 H1 F0                           ; define tool 0
              I provide you all my configuration and the requested photos.
              thank you for your professionalism.
              • Arnaud Sundefined
                Arnaud S
                my second test same error :
                M122
                Static ram: 28044
                Exception stack ram used: 528
                Never used ram: 9152
                Tasks: NETWORK(ready,116) HEAT(blocked,1228) MAIN(running,1748) IDLE(ready,80)
                Last reset 03:40:18 ago, cause: software
                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 9352 bytes (slot 1)
                Error status: 0
                SD card longest block write time: 68.6ms, max retries 4
                MCU temperature: min 40.0, current 40.5, max 44.6
                Supply voltage: min 23.9, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, SG min/max 12/145
                Driver 1: standstill, SG min/max 1/180
                Driver 3: standstill, SG min/max 0/224
                Slowest loop: 2150.65ms; fastest: 0.13ms
                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 142, MaxWait: 36555ms
                === MainDDARing ===
                Scheduled moves: 0, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 3  CDDA state: -1
                === AuxDDARing ===
                Segments left: 0
                === Network ===
                Slowest loop: 1239.61ms; fastest: 0.00ms
                - WiFi -
                WiFi flash size 4194304, free heap 21568
                  That error code does suggest a hardware fault (unless both SD cards are faulty), however it's a cloned Duet (although a legal one) so we can't really help you.
                  • Arnaud Sundefined
                    Arnaud S
                    I bought the card on Aliexpress, I thought it was an original (Sorry!). If I buy a new card on www.filafarm.de it's OK ?
                      dc42 administrators @Arnaud S
                      @Arnaud-S said in Stuck in spin loop:
                      Filafarm is one of our genuine resellers, see https://www.duet3d.com/GenuineResellers.
                      • Arnaud Sundefined
                        Arnaud S
                        Thks for all @dc42, i test with a 32Gb card (it's new card still wrapped). It's Working so ! I will test with another STL.
                        Just for information, now with the command M122 :
                          That looks a lot better than the other one!
                          • Arnaud Sundefined
                            Arnaud S
                            I like to understand the problem then I decided to find a software which allows to check the writing and reading SD card. I checked with the defective SD cards. And the result says that the SD card is defective:
                            0.5 KByte corrupted (1 sector)
                            Warning: Only 4461 of 7428 MByte tested.
                            The media is likely to be defective.
                            4.3 GByte OK (9136127 sectors)
                            0.5 KByte DATA LOST (1 sector)
                            Details:0 KByte overwritten (0 sectors)
                            0 KByte slightly changed (< 8 bit/sector, 0 sectors)
                            0 KByte aliased memory (0 sectors)
                            First error at offset: 0x000000008123ff80
                            Expected: 0x04c122acee44af80
                            Found: 0x27a7a1cd8943af80
                            Reading speed: 66.8 MByte/s
                            So now i chek all my SD card with the software H2testw (available on www.heise.de)
                              Interesting! Did the second SD card you tried also report errors?
                              • Arnaud Sundefined
                                Arnaud S
                                For the first SDCARD no error but writing 14.6MByte/s this is normal but the Reading is 14.9MByte/s maybe not fast enough for the DUET 3D which works in 20Mb.
                                First SD CARD : NO NAME 16Gb
                                Second SD CARD : EMTEC 8GB Class 10 HCI
                                So for the second, Wrinting is 16.14MB/s and Reading is 75.69Mb/s, I format low level the second card and i will check for errors with the software. Finally I use the second card to check the print.
                                • Arnaud Sundefined
                                  Arnaud S
                                  To finish, I format three times in low level the second card (EMTEC) and the error is still present.
                                  I put in trash the two SD cards:
                                  • the first because too slow
                                  • the second because defective
                                  Now on the error "Cannot read file, error code 1" I will use the software to check a malfunction on the card.
                                  FYI, my second print with the third SD CARD (type TOSHIBA 32GB SDXC I 3, formatted in FAT32 with 32Kb of cluster) works fine.
                                  Thanks for your help @dc42.
                                    Interesting that you used H2testw to find the faulty card. It was on my list of things to investigate for finding faults in SD cards but I hadn't tested it yet (no mac version).
                                    Thanks for confirming it works. I will add a note to the SD card page about using it to test for a faulty card.
