    Unsoldered Z Probe headers
    • Pakueundefined
      Pakue
      I recently received a Duet2 Ethernet and noticed that some of the Z probe connector THTs weren’t soldered when unplugging the Z probe. It was an easy fix, however it may be of interest for your QA.
      42415956-274E-481F-9802-2E1D58CC1188.jpeg D123DDF4-9C62-45F9-94F1-6819BC5FA35D.jpeg
        droftarts administrators @Pakue
        @Pakue Sorry about that! Also, looks like the PanelDue pins next to the Probe pins are unsoldered too. Did you check the rest of the board? Thanks for fixing this yourself. We will still honour the warranty.
        Can you post a picture of the top of the board? The sticker on the processor tells us who manufactured it (we use two manufacturers) and when.
        • Pakueundefined
          Pakue
          The Panel Due pins I forgot to mention, but I fixed them as well. The rest of the board looks ok and and is running just fine.
          Here is the picture of the processor sticker:
          I hope it helps. Let me know if you need further infos.
            @Pakue Thanks!
            • A Former User?
              A Former User @droftarts
              @droftarts said in Unsoldered Z Probe headers:
