    paneldue 7i does not turn on
    PanelDue
    100
    • Leblond
      Leblond last edited by
      Well another problem, connecting the 4-pin cable the display does not turn on, connecting it instead via usb of the pc it turns on, I checked the wiring and it is correct, I also checked the voltage that comes out of the cable connected to the duet2 and gives me 4.8 v the duet2 wifi is brand new, where am i wrong?
      • Leblond
        i checked if there are 5v on the paneldue connector of duet2 but i have 4.7v as 'possible this'?
        • Leblond
          @dc42 help please
          • droftarts
            droftarts administrators @Leblond last edited by
            @Leblond How is the Duet getting power? USB or VIN? Some PCs have problems powering Duet and PanelDue 7i via USB. Otherwise, check continuity on the wiring, check connections from Duet to PanelDue are correct. Post a picture of how you are connecting them if it's still not working.
            Leblond 1 Reply Last reply Reply Quote 0
            • Leblond
              Leblond @droftarts last edited by
              @droftarts VIN
              • Leblond
                I unplugged everything because I wanted to see if I had any shorts, but it is not so the card is brand new and arrived the day before yesterday
                • Leblond
                  I connected a 5v tester. and I don't have them, I only mounted the card and I did absolutely nothing, all the LEDs are perative, I send you the photo of the card on
                  • Leblond
                    • Leblond
                      it is powered by a 24v
                      • Leblond
                        by connecting the pc's usb cable, the voltage reaches between 4.54 and 4.56v.
                        • Leblond
                          • Leblond
                            on webcontrol it oscillates between 0.4 and 0.5v
                            • Leblond
                              the paneldue with the pc cable turns on very well
                              • Leblond
                                • Leblond
                                  the card came to me from filafarm germany, don't tell me I have to send it back😟
                                  • droftarts
                                    @Leblond You measure 4.57V with VIN and USB? If the Duet is powered by VIN, disconnect USB. That's what killed your last Duet!
                                    Or does the voltage drop when you connect the PanelDue?
                                    Can you show the 4-wire cable connected to the PanelDue?
                                    • Leblond
                                      @droftarts I didn't connect the card to the network, I didn't want to end the last time I was very careful if that's why, the first photo I sent you was connected to the electrical network, instead the second one was connected to the USB port of the
                                      • Leblond
                                        • Leblond
                                          I was very careful and I followed the pattern by thread and by sign
                                          • Leblond
                                            as you can see the cables are assembled well
                                            • Leblond
                                              nothing has broken the card
                                              • Leblond
                                                I was making a little reflection, admitted and not granted that the card went to be blessed, at least the 3.3 LEDs should not turn on and not even the wifi module
                                                • Leblond
                                                  but everything works, but I don't understand the voltage drop on the 5v
                                                  • Leblond
                                                    of fused cards I just need one after what I spent to get a new one, I repeat it I didn't make the mistake I made with the last one, I even put on an antistatic bracelet in handling both the card and the paneldue, I have took all necessary precautions
                                                    • Leblond
                                                      I tried to see if I have 3.3v and it is there
