TTL 12V Laser
I have this laser is there any way to directly hook it up to the Duet WIFI or do I need another board? I am very new to this but received this laser from craigslist brand new in box so I figured I would try.
Take a look through these search results: https://forum.duet3d.com/search?term=laser ttl&in=titlesposts
I know the Duet3 has some TTL connectivity: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_Connectivity
Not sure about the Duet 2, but maybe those older posts will give some info.
Sorry I can't give you more, but maybe that will get you started.
@Phaedrux Thank you
@ACSlater you ever figure it out?
@kevinsant said in TTL 12V Laser:
yes !
check this for the answer:
https://forum.duet3d.com/topic/22637/diode-laser-installation-on-duet-2-workbee-cnc
