    Delta proper endstop upgrade - advice welcome
    My Duet controlled machine
    439
    • Nxt-1
      Nxt-1 last edited by Nxt-1
      I am in the middle of planning and acquiring parts for a major revision to my Deltex build, a largeish delta printer. During the initial build I used OMRON (sub)miniature switches as endstops for the towers. While I have not had any problems that I blame these endstops for, I am thinking about getting some proper endstop switches while I am doing changes to the machine.
      Looking around, I found some nice switches from Metrol/Misumi seem to fit nice in between the 'cheapo switch that does not even spec repeatability' and the 'I just won the lottery switch that can detect movements on the Moon' categories. The exact model I am currently interested in a Metrol STE060PB. It comes in around €30 a has the following specs:
      • M6 outside diameter
      • 0.01mm repeatability
      • NC contacts
      While I still consider these to be not inexpensive, I guess you get what you pay for. What is particularly interesting to me is the way of mounting, these switches can be mounted to a tapped hole and you are done. They provide their own hard stop safety as well (as to not press the plunger to deep when overtraveling for some reason).
      Unless someone points out something I missed that would make these bad candidates I will try and convince Misumi UK to sell these to me as an individual (instead of licensed business)
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • deckingman
        deckingman @Nxt-1 last edited by
        @Nxt-1 I used a Metrol precision switch for years as a Z axis probe on my CoreXYUVAB ad found it to be very repeatable and reliable. By way of explanation, my hot end was mounted in such a way that it was constrained in X and Y but had some degree of freedom of movement in Z (against a spring). The Metrol switch was connected to the hot end mount so the nozzle was itself the probe. I did a bit of write up back in 2017 but that's way out of date now https://somei3deas.wordpress.com/2017/03/21/setting-up-a-metrol-positioning-switch/
        At that time, I managed to set up an account with Misumi. I had a business but wasn't VAT registered. I seem to recall someone saying that they've clamped down on that now and businesses have to be VAT registered, but I might be wrong. There are one or two other sources in the UK (Google is your friend) - I've even seen them on Amazon but not that exact model. I think you might be able to buy direct from Japan https://www.metrol.co.jp/en/products/#switch
        For info, I've just changed the design to suit a new hot end that I'm working on which is a cheaper alternative to the Metrol switch and arguably even more precise https://somei3deas.wordpress.com/2020/04/18/my-6-input-mixing-hot-end-part-7/
        HTH
        Nxt-1 c310 2 Replies Last reply Reply Quote 0
        • Nxt-1
          Nxt-1 @deckingman last edited by
          @deckingman An old post in some thread on hear where you mentioned that you used similar switches from Misumi is what got me looking in that direction in the first place 🙂 . Misumi clamping down is not exactly what I wanted to hear sadly. I'll have to contact them and see what they have to say I guess. Or look to alternative sources.
          Thanks for the blog links, I will check those out when I have some time.
          • jmshep
            jmshep last edited by
            Nice switches but are they OTT for limit switches? At $30 dollars they are expensive (in most currencies) for what they are required to do in my book.
            A limit switch, or endstop, has three functions; to stop movement, prevent damage and to provide a zero reference point for the software. Other than the Z axis, extreme accuracy and repeatability are not needed. Reliability is the main concern and I would source some good quality, reasonably robust, micro switches from the likes of Omron and not some of the ones widely sold for 3D printers.
            In industry, micro switches in a variety of housings are considered to be proper limit switches!
            Hope this helps.
            John S
            Nxt-1 1 Reply Last reply Reply Quote 0
            • Nxt-1
              Nxt-1 @jmshep last edited by
              @jmshep I fully agree these not inexpensive, but I feel their ease of mounting and integrated physical stopper design go a fair way of making up for that. I glanced at what it would cost to have the endstop bracket that I have been using CNC machined. All of a sudden the €30 becomes quite cheap actually. While I admit that the bracket was not optimized for metal machining, for under 30 a piece you do not get much commercial machining done.
              I am not sure whether I agree that they are over the top. To me it seems that a repeatable max height reference (which the endstops ofc provide) is a vital part to be able have an accurate coordinate system. The other vital part, especially for delta's, is the Z-probe. The 3D print community has gone to great lengths to improve Z-probe design and accuracy. It seems that this effort goes to waist if the endstops are not repeatable, as the total repeatability of the system is a function of both the endstops and Z-probe repeatability.
              Now I do not say micro switches cannot be repeatable, not at all. The issue is, while the ones I currently have are of OMRON make, they are not specced for repeatability. Which leaves me with an unknown factor here.
              deckingman Danal 2 Replies Last reply Reply Quote 0
              • deckingman
                @Nxt-1 Try other avenues first but if you get really stuck - PM me. I just went to Misumi site and picked a part number at more or less random and added it my shopping cart, then got as far as a "Place order" button. So it seems that my account is still valid.
                But be aware of 2 things that Misumi are saying - copy and paste from their site ....
                "Important notice: Due to COVID-19 our costs for importing products to Europe have increased tremendously. Therefore, an additional freight cost surcharge of 11.50 Euros per delivery will be invoiced from May 1st, 2020. Find further information here.
                Since 29. January 2020 most of the production from China has been transferred to other manufacturing sites due to the corona virus. For this reason, the lead time of some transferred products had to be extended."
                ........and once I got as far as viewing the cart, I got this
                "For this service, the consumption tax will be borne by customers."
                I'm not sure what the latter means but suspect that one might get clobbered for import duty as well. That's happened to me a couple of times recently and I've ended up paying FedEx and DHL sums of money that I didn't expect.
                So try other avenues first but if you get really stuck, PM me and we'll work out some way of me ordering them on your behalf and posting them on to you.
                • Danal
                  Danal @Nxt-1 last edited by Danal
                  @Nxt-1 said in Delta proper endstop upgrade - advice welcome:
                  Assuming the delta uses a 'smart effector' or some other probe that is always available, such as a retracting probe... and assuming that a G32 is done at the start of every print job... When the Delta finishes its G32 Z probe sequence, and resets Z0, at that moment, the endstops drop completely out of the picture. They literally have zero effect on the resulting alignment/accuracy/repeatability, etc.
                  Therefore, they only need to be "good enough" to get the effector where it can probe. Which cheap mechanical switches fulfill that mission just fine.
                  So... Delta that does not or cannot probe before each job? Better endstops do contribute to overall accuracy. Delta that probes before each job? Endstops don't matter much at all.
                  One caveat: If you plan to power-fail restart, endstops matter again. Me, personally, I'd much rather have a small UPS.
                  • Nxt-1
                    Nxt-1 @Danal last edited by
                    @Danal said in Delta proper endstop upgrade - advice welcome:
                    My delta indeed used a smart effector and a G32 is part of my normal pre-print routine. You are right that as soon as the probe routine is done, the endstops are no longer in use as long as you do not rehome. While I knew this, my brain seemed fine with ignoring the impact of this 🙂 , thank you pointing this out.
                    Yet I do want to argue that the G32 procedure constantly assumes it's XY position is acurate. Which in a delta is determined at the moment of homing. So indirectly, the repeatability of the endstops does influence the G32 procedure and its results. Though I must admit that head cannot really comprehend how much a tiny XY offset would influence the results. I assume it will not be huge.
                    Also I have sometimes saved a print from the bin after a layer shift by homing. This got by thinking about rehoming every N layers by default on very large prints.
                    Danal 1 Reply Last reply Reply Quote 0
                    • Danal
                      Yep, any kind of restart, rehome, is obviously very dependent on the upper stops.
                      Also, those switches and mounts are really cool!
                      • Nxt-1
                        @Danal Yes, the switch/mount is pretty nice. You can tell it is a product designed for that specific purpose, which probably explains the price.
                        Currently I am using a 3D printed mount that embeds the micro switch and mounts to the aluminium extrusions like this:
                        fyi, yes those are rusty nails you see right there. I did not have small enough pins and the nails where spot on the right diameter to fit the holes in the switch 🙂
                        • Danal
                          LOVE the custom pins, probably took you forever to get JUST enough iron oxide to act as a lubricant/traction interface without overwhelming the arc reactor. Microgram scale for weight/adjustment, no doubt.
                          Nxt-1 1 Reply Last reply Reply Quote 2
                          • Nxt-1
                            You are correct getting the oxide layer just the right thickness and purity took several attempts and is not recommend for the faint of hearth. I am not sure when I started the process, but it might be over 20 years ago 🙂
                            • c310
                              c310 @deckingman last edited by
                              @deckingman said in Delta proper endstop upgrade - advice welcome:
                              what will be the difference in between mechanical high precision switch and optical sensor?
                              would precision mechanics dramatically change the measurement?
                              • Nxt-1
                                Nxt-1 @c310 last edited by
                                @c310 said in Delta proper endstop upgrade - advice welcome:
                                My two cents is that opticals can be more repeatable than mechanical and vice versa. I am not expect by any means though. The main reason I have not given them serious consideration is implementation difficulty.
                                To accurately trigger optical sensors you need to interrupt the optical path with some kind of a flag. I am no fan of implementing something tiny that stick out on top of the moving carriage. Especially not if it most likely will be printed and needs to be accurate across the three towers. Also as far as I know you always need an additional form of a physical stop in case an endstop fails to trigger for some reason.
                                Ambient light influences should be mentioned I guess when talking about optical sensors. But again, not an expert on the matter here.
                                  Phaedrux Moderator @Nxt-1 last edited by
                                  Given the way the sensor is shrouded, it would be very difficult for ambient light to interfere with it I think.
                                  The flag position should ideally be adjustable, so that exact positioning isn't needed. You can just turn the screw to adjust it. The LED on the endstop makes adjusting it quite easy.
                                  so optical can be quite beneficial, especially if you need an endstop that you can physically travel through if needed.
                                  • Nxt-1
                                    Just for the sake of keeping this thread complete, I have placed an order with Cncsystems Ltd (UK) for some Metrol STE060PB's. They should be arriving by the end of May.
