    Duet Maestro BLV AM8 upgrade
    • lich
      lich last edited by
      Hi Hoping some one can help ,I have been through the forum read all the post and tried all the fixe's .
      Fitted a Maestro to an anet a8 that has had an BLV AM8 upgrade.
      The x carriage and Y carriage will not move ,The Z carriage makes a horrible clicking sound when it moves .
      Home X the Z carriage moves home Y the Z carriage moves, It will not see the endstops .
      The extruder will not Move .
      The only thing left from the anet is four stepper motors and two endstops.
      The Duet has been upgraded to 3.01
      Her is a copy of my config file
      M550 P"Lich3D" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X100.00 Y100.00 Z400.00 E873.08 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-33 Y-10 Z0 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S0 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
      M950 S0 C"zprobe.mod." ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F100 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X20:200 Y20:200 S40 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      T0 ; select first tool
      Any guidance would been helpful
      PaulHew dc42 2 Replies Last reply Reply Quote 0
      • PaulHew
        PaulHew @lich last edited by
        @lich Do the endstops register in DWC, on the 'Machine-Specific' page when you manually trigger them?
        Please post a picture of your endstop wiring, board side and check that you used the outer pins in the 3 pin connector.
        If Z is moving when homing X, could point to a possible wiring issue or wrong socket, maybe.
        P.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • lich
          lich last edited by
          The endstops do not register in dwc when triggerd I have wired them to the outer pins on the board,
          I have check the wiring to the X Y Z axis all in the right sockets ,the wiring to the duet maestro is as the diagram states
            dc42 administrators @lich last edited by
            @lich said in Duet Maestro BLV AM8 upgrade:
            You appear to be using normally-open endstop switches and RRF 3.x. Change those lines to:
            M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
            lich 1 Reply Last reply Reply Quote 0
            • lich
              lich @dc42 last edited by
              @dc42 said in Duet Maestro BLV AM8 upgrade:
              Thank you dc42 that has got the endstops working
