    RRF 3.01-RC10, DWC 2.1.5 and DSF 2.1.1 released
    Beta Firmware
    15
    50
    2.4k
      On behalf of the Duet3D team I am pleased to announce the release of this new firmware/software bundle. This fixes bugs that have been reported in the previous bundle (RRF 3.01-RC9, DWC 2.1.4, DSF 2.1.0).
      Users of Duet 3 + Raspberry Pi can upgrade to this bundle from the unstable package feed using sudo apt-get update and sudo apt get upgrade as usual. All other Duet users can get it from https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC10.
      RRF 3.01-RC10 release notes: https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
      DWC 2.1.5 release notes: https://github.com/chrishamm/DuetWebControl/blob/master/WHATS_NEW.md
      DSF 2.1.1 release notes: https://github.com/chrishamm/DuetSoftwareFramework/blob/dev/WHATS_NEW.md
      If you find any issues with this release, please start a new thread for each one (unless there is already a thread devoted to that issue) and link to that thread in a 1-line post in this thread.
      • A Former User?
        A Former User
        @dc42 said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
        WHATS_NEW_RRF3.md
        WHATS_NEW_RRF3.md isn't linked to in the release page, glitch or new format perhaps?
        (I think I'd like to see the https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview link on that page as well as an increasing number of new users will start upgrading)
          Thanks, I've added that link.
          • A Former User?
            A Former User
            https://forum.duet3d.com/topic/15848/dsf-2-1-1-hangs-on-apt-upgrade-with-no-duet-connected (sort of case closed)
            • Silroccoundefined
              Silrocco
              Hello.
              I'm getting an error when uploading the DuetMaestroFirmware.bin to a Maestro.
              M997 S0
              Error: M997: In-application programming binary "DuetMaestroIAP.bin" not found
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.01-RC8 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-04-17b4
              I can upload the Duet2CombinedFirmware successfully, NOT the DuetMaestroFirmware.
              • chrishammundefined
                chrishamm administrators @Silrocco
                @Silrocco The file you are looking for (DuetMaestroIAP.bin) is available here: https://github.com/dc42/RepRapFirmware/releases/tag/3.0 Please upload that before you upload the firmware file.
                Duet software engineer
                Silroccoundefined 1 Reply Last reply Reply Quote 0
                • Silroccoundefined
                  Silrocco
                  @chrishamm
                  Thanks. I'm currently printing a part so when done I'll attempt uploading it.
                  • gloomyandyundefined
                    gloomyandy
                    is the github repo fully up to date? It is tagged as RC10, but the Version.h file claims to be RC9+1 (and this is the version reported by DWC when using an LPC build).
                    https://github.com/dc42/RepRapFirmware/blob/3.01-RC10/src/Version.h
                    Thanks!
                      I'm sorry, it looks like I may have failed to commit that file before I did the release. That was the very last change I made. All other changes were in previous commits.
                        gloomyandy
                        If that is the only file I wouldn't worry about it David.
                        • Silroccoundefined
                          Silrocco @chrishamm
                          @chrishamm
                          Uploading DuetMaestroAP.bin didn't work either, getting an infinite upload status for minutes that I have to cancel out. 43e2b496-b8df-4dfe-af15-c54e80548d97-image.png
                            dc42 administrators @gloomyandy
                            @gloomyandy said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
                            I'm not worried - I just need to avoid making the same mistake when I do the 3.01 stable release ☺
                              dc42 administrators @Silrocco
                              @Silrocco said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
                              @chrishamm
                              Is that repeatable? What is the file size of the DuetMaestroAP.bin file on your PC?
                              Silroccoundefined themelleundefined 2 Replies Last reply Reply Quote 0
                              • arhiundefined
                                arhi
                                Duet WiFi, Ethernet and Maestro: a default bed heater is no longer created, so you need to use M140 H0 in config.g if you want to replicate the prevous behaviour. The online configurator already generates this command automatically when you configure a bed heater. Any M143 H0 command must come later in config.g than the M140 H0 command, because M140 resets the temperature limit for the heater to the default for bed heaters.
                                This is confusing to me so need to check. M140 is used to set the bed temp? What is new, to set the bed temp we now need to do M140 H0 S100 in g-code for the job or ? Why would that ever be in config.g ? Shouldn't config.g only be M308 S0 to define bed temp sensor and M950 H0 to create bed heater?
                                Am I missing something or ?
                                M140
                                RepRapFirmware also provides an optional 'H' parameter to set the hot bed heater number(s). If no heated bed is present, a negative value may be specified to disable it. M140 commands with H parameters would normally be used only in the config.g file.
                                So maybe M140 H0 P0 does what's required? if it does, I have to say it's not clear from the documentation 😞 few more words would have to be added both for M950 and M140 🙂
                                • c310undefined
                                  c310
                                  i am not able to get heat bed configured:
                                  M308 S0 P"bed_temp" Y"thermistor" T100000 B4250 R4700  	; define bed termistor sensor
                                  M950 H0 C"bed_heat" T0 					; heater 0 uses the bed_heat pin, sensor 0
                                  once i issue M140 S40
                                  Error: M140: No bed heater has been configured for slot 0
                                  and i do no see heat bed on DWC
                                  what is wrong? please advice how to treat it 🙂
                                  arhiundefined 1 Reply Last reply Reply Quote 0
                                    In response to the last 2 posts: READ THE UPGRADE NOTES!!!!
                                    Why do I bother to write them?
                                    arhiundefined c310undefined 2 Replies Last reply Reply Quote 0
                                    • arhiundefined
                                      arhi @c310
                                      @c310 add
                                      M140 H0 P0
                                      after M950
                                        @arhi https://duet3d.dozuki.com/Wiki/Gcode#Section_M140_Set_Bed_Temperature_Fast
                                        It's basically just telling the firmware that heater is a bed so that it uses appropriate values for a bed heater by default. There have been many people with issues where their bed would give heater faults for heating too slowly because the firmware was expecting it to act like a hotend by default. This change just informs the firmware that it is a bed again.
                                        At least I think that's what's going on.
                                        • arhiundefined
                                          arhi @dc42
                                          @dc42 I did, and I got it working but is very unclear 😞
                                          I created a heater already so "no longer created", but I just did .. I just added the code and it works but ... maybe
                                          "default bed heater is no longer auto assigned, so you need to assign it using M140; use M140 H0 in config.g ..."
                                          I know I'm nitpicking and you have more important things to do but looking at M140 amd M950 there's nothing about assigning heater to this or that
                                            dc42 administrators @arhi
                                            @arhi said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
                                            The upgrade notes are:
                                            Upgrade notes:
                                            If you tell me what you didn't find clear, I will try to improve the text.
                                            arhiundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
